Alexander Soare 03b08eb74e backup wip
2024-04-16 12:51:32 +01:00
67 lines
2.5 KiB
import os
from lerobot.common.datasets.utils import cycle
training_steps = 5000
device = torch.device("cuda")
log_freq = 250
# Set up the dataset.
cfg = init_hydra_config("lerobot/configs/default.yaml", overrides=["env=pusht"])
dataset = make_dataset(cfg)
# Set up the the policy.
cfg = DiffusionConfig()
policy.train()
policy.to(device)
dataset,
num_workers=4,
batch_size=cfg.batch_size,
shuffle=True,
drop_last=True,
# Run training loop.
dataloader = cycle(dataloader)
for step in range(training_steps):
batch = {k: v.to(device, non_blocking=True) for k, v in next(dataloader).items()}
info = policy(batch)
if step % log_freq == 0:
num_samples = (step + 1) * cfg.batch_size
loss = info["loss"]
update_s = info["update_s"]
print(f"step: {step} samples: {num_samples} loss: {loss:.3f} update_time: {update_s:.3f} (seconds)")
OmegaConf.save(cfg, output_directory / "config.yaml")
