Lerobot/examples/3_evaluate_pretrained_policy.py
Remi 0928afd37d
Improve dataset examples (#82)
2024-04-18 11:43:16 +02:00
41 lines
1.3 KiB
# TODO(alexander-soare): This no longer works until we upload a new model that uses the current configs.
# folder = Path("outputs/train/example_pusht_diffusion")
stats_path = folder / "stats.pth" # normalization stats
overrides = [
"eval_episodes=10",
"rollout_batch_size=10",
"device=cuda",
# Create a Hydra config.
eval(
cfg,
stats_path=stats_path,
