Lerobot/examples/1_load_lerobot_dataset.py
Remi 19812ca470
Add dataset visualization with rerun.io (#131)
2024-05-04 16:07:14 +02:00
94 lines
4.4 KiB
- Loading a dataset and accessing its properties.
- Filtering data by episode number.
- Converting tensor data for visualization.
- Saving video files from dataset frames.
import imageio
import lerobot
print("List of available datasets", lerobot.available_datasets)
# # >>> ['lerobot/aloha_sim_insertion_human', 'lerobot/aloha_sim_insertion_scripted',
# # 'lerobot/aloha_sim_transfer_cube_human', 'lerobot/aloha_sim_transfer_cube_scripted',
# # 'lerobot/pusht', 'lerobot/xarm_lift_medium']
repo_id = "lerobot/pusht"
# You can easily load a dataset from a Hugging Face repositery
# LeRobotDataset is actually a thin wrapper around an underlying Hugging Face dataset (see https://huggingface.co/docs/datasets/index for more information).
# TODO(rcadene): update to make the print pretty
print(f"{dataset=}")
print(f"{dataset.hf_dataset=}")
# and provides additional utilities for robotics and compatibility with pytorch
print(f"number of samples/frames: {dataset.num_samples=}")
print(f"number of episodes: {dataset.num_episodes=}")
print(f"average number of frames per episode: {dataset.num_samples / dataset.num_episodes:.3f}")
print(f"frames per second used during data collection: {dataset.fps=}")
print(f"keys to access images from cameras: {dataset.image_keys=}")
# Access frame indexes associated to first episode
episode_index = 0
from_idx = dataset.episode_data_index["from"][episode_index].item()
to_idx = dataset.episode_data_index["to"][episode_index].item()
# LeRobot datasets actually subclass PyTorch datasets so you can do everything you know and love from working with the latter, like iterating through the dataset.
# Here we grab all the image frames.
frames = [dataset[idx]["observation.image"] for idx in range(from_idx, to_idx)]
# Video frames are now float32 in range [0,1] channel first (c,h,w) to follow pytorch convention.
# To visualize them, we convert to uint8 range [0,255]
frames = [(frame * 255).type(torch.uint8) for frame in frames]
# and to channel last (h,w,c).
frames = [frame.permute((1, 2, 0)).numpy() for frame in frames]
# Finally, we save the frames to a mp4 video for visualization.
Path("outputs/examples/1_load_lerobot_dataset").mkdir(parents=True, exist_ok=True)
imageio.mimsave("outputs/examples/1_load_lerobot_dataset/episode_0.mp4", frames, fps=dataset.fps)
# For many machine learning applications we need to load the history of past observations or trajectories of future actions.
# Our datasets can load previous and future frames for each key/modality,
# using timestamps differences with the current loaded frame. For instance:
delta_timestamps = {
"observation.image": [-1, -0.5, -0.20, 0],
# loads 8 state vectors: 1.5 seconds before, 1 second before, ... 20 ms, 10 ms, and current frame
"observation.state": [-1.5, -1, -0.5, -0.20, -0.10, -0.02, -0.01, 0],
print(f"{dataset[0]['observation.image'].shape=}") # (4,c,h,w)
print(f"{dataset[0]['observation.state'].shape=}") # (8,c)
print(f"{dataset[0]['action'].shape=}") # (64,c)
# Finally, our datasets are fully compatible with PyTorch dataloaders and samplers
# because they are just PyTorch datasets.
dataset,
num_workers=0,
batch_size=32,
shuffle=True,
for batch in dataloader:
print(f"{batch['observation.image'].shape=}") # (32,4,c,h,w)
print(f"{batch['observation.state'].shape=}") # (32,8,c)
print(f"{batch['action'].shape=}") # (32,64,c)
break
