Alexander Soare a4891095e4
Use PytorchModelHubMixin to save models as safetensors (#125)
2024-05-01 16:17:18 +01:00
28 lines
1.0 KiB
pretrained_policy_name = "lerobot/diffusion_policy_pusht_image"
pretrained_policy_path = Path(snapshot_download(pretrained_policy_name))
overrides = [
"eval.n_episodes=10",
"eval.batch_size=10",
"device=cuda",
# TODO(rcadene, alexander-soare): dont call eval, but add the minimal code snippet to rollout
eval(pretrained_policy_path=pretrained_policy_path)
