Lerobot/examples/1_visualize_dataset.py
Alexander Soare 1a1308d62f fix environment seeding
add fixes for reproducibility
only try to start env if it is closed
revision
fix normalization and data type
Improve README
Improve README
Tests are passing, Eval pretrained model works, Add gif
Update gif
Update gif
Update gif
Update gif
Update README
Update README
update minor
Update README.md
Update README.md
Address suggestions
Update thumbnail + stats
Update README.md
Add more comments
Add test_examples.py
2024-03-26 10:10:43 +00:00
23 lines
786 B
from torchrl.data.replay_buffers import SamplerWithoutReplacement
import lerobot
from lerobot.common.datasets.aloha import AlohaDataset
from lerobot.scripts.visualize_dataset import render_dataset
print(lerobot.available_datasets)
# >>> ['aloha_sim_insertion_human', 'aloha_sim_insertion_scripted', 'aloha_sim_transfer_cube_human', 'aloha_sim_transfer_cube_scripted', 'pusht', 'xarm_lift_medium']
# we use this sampler to sample 1 frame after the other
sampler = SamplerWithoutReplacement(shuffle=False)
dataset = AlohaDataset("aloha_sim_transfer_cube_human", sampler=sampler)
video_paths = render_dataset(
dataset,
out_dir="outputs/visualize_dataset/example",
max_num_samples=300,
fps=50,
print(video_paths)
# ['outputs/visualize_dataset/example/episode_0.mp4']
