56 lines
1.6 KiB
import os
from tqdm import trange
from lerobot.common.datasets.factory import make_offline_buffer
from lerobot.common.policies.diffusion.policy import DiffusionPolicy
overrides = [
"env=pusht",
"policy=diffusion",
"offline_steps=5000",
"log_freq=250",
"device=cuda",
cfg = init_hydra_config("lerobot/configs/default.yaml", overrides)
policy = DiffusionPolicy(
cfg=cfg.policy,
cfg_device=cfg.device,
cfg_noise_scheduler=cfg.noise_scheduler,
cfg_rgb_model=cfg.rgb_model,
cfg_obs_encoder=cfg.obs_encoder,
cfg_optimizer=cfg.optimizer,
cfg_ema=cfg.ema,
n_action_steps=cfg.n_action_steps,
**cfg.policy,
policy.train()
offline_buffer = make_offline_buffer(cfg)
for offline_step in trange(cfg.offline_steps):
train_info = policy.update(offline_buffer, offline_step)
if offline_step % cfg.log_freq == 0:
print(train_info)
OmegaConf.save(cfg, output_directory / "config.yaml")
torch.save(offline_buffer.transform[-1].stats, output_directory / "stats.pth")
