Simon Alibert bf2eebb090
Update readme & remove example 1 (#108)
- Update instructions for installing the library
- Remove deprecated example 1 (as we are now only using `LeRobotDataset` since #91)
2024-04-27 09:48:02 +02:00
39 lines
1.2 KiB
# TODO(alexander-soare): This no longer works until we upload a new model that uses the current configs.
# folder = Path("outputs/train/example_pusht_diffusion")
overrides = [
"eval_episodes=10",
"rollout_batch_size=10",
"device=cuda",
# Create a Hydra config.
eval(
cfg,
