Simon Alibert 2765877f28
Speed up CI, add more checks (#115)
- Split pytest and end-to-end tests into separate jobs
- Add poetry check to ensure pyproject.toml and poetry.lock are in sync
- Add ruff format --diff to ensure style formatting is applied (fails if ruff would reformat anything)
2024-04-29 23:05:55 +02:00
77 lines
2.6 KiB
import os
training_steps = 5000
device = torch.device("cuda")
log_freq = 250
# Set up the dataset.
# Set up the the policy.
cfg = DiffusionConfig()
policy = DiffusionPolicy(cfg, lr_scheduler_num_training_steps=training_steps, dataset_stats=dataset.stats)
policy.train()
policy.to(device)
optimizer = torch.optim.Adam(
policy.diffusion.parameters(), cfg.lr, cfg.adam_betas, cfg.adam_eps, cfg.adam_weight_decay
dataset,
num_workers=4,
batch_size=cfg.batch_size,
shuffle=True,
drop_last=True,
# Run training loop.
step = 0
done = False
while not done:
for batch in dataloader:
loss = output_dict["loss"]
loss.backward()
optimizer.step()
optimizer.zero_grad()
if step % log_freq == 0:
step += 1
if step >= training_steps:
done = True
break
# Save the policy and configuration for later use.
