2024-04-16 14:07:16 +01:00
75 lines
2.6 KiB
import os
training_steps = 5000
device = torch.device("cuda")
log_freq = 250
# Set up the dataset.
# Set up the the policy.
cfg = DiffusionConfig()
policy.train()
policy.to(device)
dataset,
num_workers=4,
batch_size=cfg.batch_size,
shuffle=True,
drop_last=True,
# Run training loop.
step = 0
done = False
while not done:
for batch in dataloader:
for k in batch:
batch[k] = batch[k].to(device, non_blocking=True)
info = policy(batch)
if step % log_freq == 0:
num_samples = (step + 1) * cfg.batch_size
loss = info["loss"]
update_s = info["update_s"]
print(
f"step: {step} samples: {num_samples} loss: {loss:.3f} update_time: {update_s:.3f} (seconds)"
step += 1
if step >= training_steps:
done = True
break
