Lerobot/examples/1_load_lerobot_dataset.py
Simon Alibert 32eb0cec8f
Dataset v2.0 (#461)
2024-11-29 19:04:00 +01:00
135 lines
5.8 KiB
- Viewing a dataset's metadata and exploring its properties.
- Loading an existing dataset from the hub or a subset of it.
- Accessing frames by episode number.
from pprint import pprint
from huggingface_hub import HfApi
import lerobot
# We ported a number of existing datasets ourselves, use this to see the list:
print("List of available datasets:")
pprint(lerobot.available_datasets)
# You can also browse through the datasets created/ported by the community on the hub using the hub api:
hub_api = HfApi()
repo_ids = [info.id for info in hub_api.list_datasets(task_categories="robotics", tags=["LeRobot"])]
pprint(repo_ids)
# Or simply explore them in your web browser directly at:
# https://huggingface.co/datasets?other=LeRobot
# Let's take this one for this example
repo_id = "lerobot/aloha_mobile_cabinet"
# We can have a look and fetch its metadata to know more about it:
ds_meta = LeRobotDatasetMetadata(repo_id)
# By instantiating just this class, you can quickly access useful information about the content and the
# structure of the dataset without downloading the actual data yet (only metadata files — which are
# lightweight).
print(f"Total number of episodes: {ds_meta.total_episodes}")
print(f"Average number of frames per episode: {ds_meta.total_frames / ds_meta.total_episodes:.3f}")
print(f"Frames per second used during data collection: {ds_meta.fps}")
print(f"Robot type: {ds_meta.robot_type}")
print(f"keys to access images from cameras: {ds_meta.camera_keys=}\n")
print("Tasks:")
print(ds_meta.tasks)
print("Features:")
pprint(ds_meta.features)
# You can also get a short summary by simply printing the object:
print(ds_meta)
# You can then load the actual dataset from the hub.
# Either load any subset of episodes:
dataset = LeRobotDataset(repo_id, episodes=[0, 10, 11, 23])
# And see how many frames you have:
print(f"Selected episodes: {dataset.episodes}")
print(f"Number of episodes selected: {dataset.num_episodes}")
print(f"Number of frames selected: {dataset.num_frames}")
# Or simply load the entire dataset:
# The previous metadata class is contained in the 'meta' attribute of the dataset:
print(dataset.meta)
# LeRobotDataset actually wraps an underlying Hugging Face dataset
# (see https://huggingface.co/docs/datasets for more information).
print(dataset.hf_dataset)
# LeRobot datasets also subclasses PyTorch datasets so you can do everything you know and love from working
# with the latter, like iterating through the dataset.
# The __getitem__ iterates over the frames of the dataset. Since our datasets are also structured by
# episodes, you can access the frame indices of any episode using the episode_data_index. Here, we access
# frame indices associated to the first episode:
episode_index = 0
from_idx = dataset.episode_data_index["from"][episode_index].item()
to_idx = dataset.episode_data_index["to"][episode_index].item()
# Then we grab all the image frames from the first camera:
camera_key = dataset.meta.camera_keys[0]
frames = [dataset[idx][camera_key] for idx in range(from_idx, to_idx)]
# The objects returned by the dataset are all torch.Tensors
print(type(frames[0]))
print(frames[0].shape)
# Since we're using pytorch, the shape is in pytorch, channel-first convention (c, h, w).
# We can compare this shape with the information available for that feature
pprint(dataset.features[camera_key])
# In particular:
print(dataset.features[camera_key]["shape"])
# The shape is in (h, w, c) which is a more universal format.
# For many machine learning applications we need to load the history of past observations or trajectories of
# future actions. Our datasets can load previous and future frames for each key/modality, using timestamps
# differences with the current loaded frame. For instance:
delta_timestamps = {
camera_key: [-1, -0.5, -0.20, 0],
# loads 8 state vectors: 1.5 seconds before, 1 second before, ... 200 ms, 100 ms, and current frame
"observation.state": [-1.5, -1, -0.5, -0.20, -0.10, 0],
# Note that in any case, these delta_timestamps values need to be multiples of (1/fps) so that added to any
# timestamp, you still get a valid timestamp.
print(f"\n{dataset[0][camera_key].shape=}") # (4, c, h, w)
print(f"{dataset[0]['observation.state'].shape=}") # (6, c)
print(f"{dataset[0]['action'].shape=}\n") # (64, c)
# Finally, our datasets are fully compatible with PyTorch dataloaders and samplers because they are just
# PyTorch datasets.
dataset,
num_workers=0,
batch_size=32,
shuffle=True,
for batch in dataloader:
print(f"{batch[camera_key].shape=}") # (32, 4, c, h, w)
print(f"{batch['observation.state'].shape=}") # (32, 5, c)
print(f"{batch['action'].shape=}") # (32, 64, c)
break
