2025-04-09 17:44:32 +02:00
140 lines
4.6 KiB
```bash
pip install -e ".[pusht]"
import gym_pusht # noqa: F401
import gymnasium as gym
import imageio
import numpy
# Select your device
device = "cuda"
env = gym.make(
"gym_pusht/PushT-v0",
obs_type="pixels_agent_pos",
max_episode_steps=300,
# produced by the environment
print(env.observation_space)
# environment
print(env.action_space)
policy.reset()
rewards = []
frames = []
frames.append(env.render())
step = 0
done = False
while not done:
# to channel last in [0,1]
state = state.unsqueeze(0)
image = image.unsqueeze(0)
observation = {
"observation.state": state,
"observation.image": image,
with torch.inference_mode():
rewards.append(reward)
step += 1
if terminated:
print("Success!")
else:
print("Failure!")
