Alexander Soare be4441c7ff update README
2024-03-26 16:28:16 +00:00
40 lines
1.2 KiB
# folder = Path("outputs/train/example_pusht_diffusion")
stats_path = folder / "stats.pth" # normalization stats
overrides = [
"eval_episodes=10",
"rollout_batch_size=10",
"device=cuda",
# Create a Hydra config.
eval(
cfg,
stats_path=stats_path,
