Simon Alibert bf2eebb090
Update readme & remove example 1 (#108)
- Update instructions for installing the library
- Remove deprecated example 1 (as we are now only using `LeRobotDataset` since #91)
2024-04-27 09:48:02 +02:00
68 lines
2.4 KiB
import os
training_steps = 5000
device = torch.device("cuda")
log_freq = 250
# Set up the dataset.
# Set up the the policy.
cfg = DiffusionConfig()
policy = DiffusionPolicy(cfg, lr_scheduler_num_training_steps=training_steps, dataset_stats=dataset.stats)
policy.train()
policy.to(device)
dataset,
num_workers=4,
batch_size=cfg.batch_size,
shuffle=True,
drop_last=True,
# Run training loop.
step = 0
done = False
while not done:
for batch in dataloader:
info = policy.update(batch)
if step % log_freq == 0:
print(f"step: {step} loss: {info['loss']:.3f} update_time: {info['update_s']:.3f} (seconds)")
step += 1
if step >= training_steps:
done = True
break
# Save the policy and configuration for later use.
