Lerobot/examples/4_calculate_validation_loss.py
2024-05-20 14:04:04 +02:00
72 lines
2.8 KiB
"""This script demonstrates how to slice a dataset and calculate the loss on a subset of the data.
This technique can be useful for debugging and testing purposes, as well as identifying whether a policy
is learning effectively.
Furthermore, relying on validation loss to evaluate performance is generally not considered a good practice,
especially in the context of imitation learning. The most reliable approach is to evaluate the policy directly
on the target environment, whether that be in simulation or the real world.
device = torch.device("cuda")
# Download the diffusion policy for pusht environment
pretrained_policy_path = Path(snapshot_download("lerobot/diffusion_pusht"))
policy.eval()
policy.to(device)
# Set up the dataset.
delta_timestamps = {
# used to calculate the loss.
# Load the last 10 episodes of the dataset as a validation set.
# The `split` argument utilizes the `datasets` library's syntax for slicing datasets.
# For more information on the Slice API, please see:
# https://huggingface.co/docs/datasets/v2.19.0/loading#slice-splits
val_dataset = LeRobotDataset("lerobot/pusht", split="train[24342:]", delta_timestamps=delta_timestamps)
# Create dataloader for evaluation.
val_dataloader = torch.utils.data.DataLoader(
val_dataset,
num_workers=4,
batch_size=64,
shuffle=False,
drop_last=False,
# Run validation loop.
loss_cumsum = 0
n_examples_evaluated = 0
for batch in val_dataloader:
loss_cumsum += output_dict["loss"].item()
n_examples_evaluated += batch["index"].shape[0]
# Calculate the average loss over the validation set.
average_loss = loss_cumsum / n_examples_evaluated
print(f"Average loss on validation set: {average_loss:.4f}")
