2024-04-30 16:08:59 +01:00
39 lines
1.2 KiB
# TODO(alexander-soare): This no longer works until we upload a new model that uses the current configs.
# folder = Path("outputs/train/example_pusht_diffusion")
overrides = [
"eval.n_episodes=10",
"eval.batch_size=10",
"device=cuda",
# Create a Hydra config.
eval(
cfg,
