Lerobot/examples/2_load_lerobot_dataset.py
2024-04-19 12:36:04 +02:00
99 lines
4.6 KiB
This script demonstrates the use of the PushtDataset class for handling and processing robotic datasets from Hugging Face.
- Loading a dataset and accessing its properties.
- Filtering data by episode number.
- Converting tensor data for visualization.
- Saving video files from dataset frames.
To try a different Hugging Face dataset, you can replace:
```python
dataset = PushtDataset()
by one of these:
```python
dataset = XarmDataset()
dataset = AlohaDataset("aloha_sim_insertion_human")
dataset = AlohaDataset("aloha_sim_insertion_scripted")
dataset = AlohaDataset("aloha_sim_transfer_cube_human")
dataset = AlohaDataset("aloha_sim_transfer_cube_scripted")
import imageio
from lerobot.common.datasets.pusht import PushtDataset
# TODO(rcadene): List available datasets and their dataset ids (e.g. PushtDataset, AlohaDataset(dataset_id="aloha_sim_insertion_human"))
# print("List of available datasets", lerobot.available_datasets)
# # >>> ['aloha_sim_insertion_human', 'aloha_sim_insertion_scripted',
# # 'aloha_sim_transfer_cube_human', 'aloha_sim_transfer_cube_scripted',
# # 'pusht', 'xarm_lift_medium']
# You can easily load datasets from LeRobot
# All LeRobot datasets are actually a thin wrapper around an underlying Hugging Face dataset (see https://huggingface.co/docs/datasets/index for more information).
print(f"{dataset=}")
print(f"{dataset.hf_dataset=}")
# and provide additional utilities for robotics and compatibility with pytorch
print(f"number of samples/frames: {dataset.num_samples=}")
print(f"number of episodes: {dataset.num_episodes=}")
print(f"average number of frames per episode: {dataset.num_samples / dataset.num_episodes:.3f}")
print(f"frames per second used during data collection: {dataset.fps=}")
print(f"keys to access images from cameras: {dataset.image_keys=}")
# While the LeRobot dataset adds helpers for working within our library, we still expose the underling Hugging Face dataset. It may be freely replaced or modified in place. Here we use the filtering to keep only frames from episode 5.
dataset.hf_dataset = dataset.hf_dataset.filter(lambda frame: frame["episode_id"] == 5)
# LeRobot datsets actually subclass PyTorch datasets. So you can do everything you know and love from working with the latter, for example: iterating through the dataset. Here we grap all the image frames.
frames = [sample["observation.image"] for sample in dataset]
# but frames are now channel first to follow pytorch convention,
# to view them, we convert to channel last
frames = [frame.permute((1, 2, 0)).numpy() for frame in frames]
# and finally save them to a mp4 video
Path("outputs/examples/2_load_lerobot_dataset").mkdir(parents=True, exist_ok=True)
imageio.mimsave("outputs/examples/2_load_lerobot_dataset/episode_5.mp4", frames, fps=dataset.fps)
# For many machine learning applications we need to load histories of past observations, or trajectorys of future actions. Our datasets can load previous and future frames for each key/modality,
# using timestamps differences with the current loaded frame. For instance:
delta_timestamps = {
"observation.image": [-1, -0.5, -0.20, 0],
# loads 8 state vectors: 1.5 seconds before, 1 second before, ... 20 ms, 10 ms, and current frame
"observation.state": [-1.5, -1, -0.5, -0.20, -0.10, -0.02, -0.01, 0],
dataset = PushtDataset(delta_timestamps=delta_timestamps)
print(f"{dataset[0]['observation.image'].shape=}") # (4,c,h,w)
print(f"{dataset[0]['observation.state'].shape=}") # (8,c)
print(f"{dataset[0]['action'].shape=}") # (64,c)
# Finally, our datasets are fully compatible with PyTorch dataloaders and samplers
# because they are just PyTorch datasets.
dataset,
num_workers=0,
batch_size=32,
shuffle=True,
for batch in dataloader:
print(f"{batch['observation.image'].shape=}") # (32,4,c,h,w)
print(f"{batch['observation.state'].shape=}") # (32,8,c)
print(f"{batch['action'].shape=}") # (32,64,c)
break
