Simon Alibert f5e76393eb
Release cleanup (#132)
Co-authored-by: Kashif Rasul <kashif.rasul@gmail.com>
Co-authored-by: Adil Zouitine <adilzouitinegm@gmail.com>
Co-authored-by: Cadene <re.cadene@gmail.com>
2024-05-06 03:03:14 +02:00
113 lines
3.6 KiB
import gym_pusht # noqa: F401
import gymnasium as gym
import imageio
import numpy
device = torch.device("cuda")
# Download the diffusion policy for pusht environment
pretrained_policy_path = Path(snapshot_download("lerobot/diffusion_pusht"))
policy.eval()
policy.to(device)
env = gym.make(
"gym_pusht/PushT-v0",
obs_type="pixels_agent_pos",
max_episode_steps=300,
# Reset the policy and environmens to prepare for rollout
policy.reset()
rewards = []
frames = []
frames.append(env.render())
step = 0
done = False
while not done:
# to channel last in [0,1]
state = state.unsqueeze(0)
image = image.unsqueeze(0)
observation = {
"observation.state": state,
"observation.image": image,
with torch.inference_mode():
rewards.append(reward)
step += 1
if terminated:
print("Success!")
else:
print("Failure!")
