Simon Alibert f5e76393eb
Release cleanup (#132)
Co-authored-by: Kashif Rasul <kashif.rasul@gmail.com>
Co-authored-by: Adil Zouitine <adilzouitinegm@gmail.com>
Co-authored-by: Cadene <re.cadene@gmail.com>
2024-05-06 03:03:14 +02:00
80 lines
2.8 KiB
training_steps = 5000
device = torch.device("cuda")
log_freq = 250
# Set up the dataset.
delta_timestamps = {
# Set up the the policy.
cfg = DiffusionConfig()
policy = DiffusionPolicy(cfg, dataset_stats=dataset.stats)
policy.train()
policy.to(device)
dataset,
num_workers=4,
batch_size=64,
shuffle=True,
drop_last=True,
# Run training loop.
step = 0
done = False
while not done:
for batch in dataloader:
loss = output_dict["loss"]
loss.backward()
optimizer.step()
optimizer.zero_grad()
if step % log_freq == 0:
step += 1
if step >= training_steps:
done = True
break
# Save a policy checkpoint.
