2024-04-10 13:45:45 +00:00
69 lines
1.9 KiB
import os
from lerobot.common.policies.diffusion.policy import DiffusionPolicy
overrides = [
"env=pusht",
"policy=diffusion",
"offline_steps=5000",
"log_freq=250",
"device=cuda",
cfg = init_hydra_config("lerobot/configs/default.yaml", overrides)
policy = DiffusionPolicy(
cfg=cfg.policy,
cfg_device=cfg.device,
cfg_noise_scheduler=cfg.noise_scheduler,
cfg_rgb_model=cfg.rgb_model,
cfg_obs_encoder=cfg.obs_encoder,
cfg_optimizer=cfg.optimizer,
cfg_ema=cfg.ema,
**cfg.policy,
policy.train()
dataset = make_dataset(cfg)
# create dataloader for offline training
dataset,
num_workers=4,
batch_size=cfg.policy.batch_size,
shuffle=True,
pin_memory=cfg.device != "cpu",
drop_last=True,
for step, batch in enumerate(dataloader):
info = policy(batch, step)
if step % cfg.log_freq == 0:
num_samples = (step + 1) * cfg.policy.batch_size
loss = info["loss"]
update_s = info["update_s"]
print(f"step:{step} samples:{num_samples} loss:{loss:.3f} update_time:{update_s:.3f}(seconds)")
OmegaConf.save(cfg, output_directory / "config.yaml")
