Simon Alibert 32eb0cec8f
Dataset v2.0 (#461)
2024-11-29 19:04:00 +01:00
80 lines
2.8 KiB
training_steps = 5000
device = torch.device("cuda")
log_freq = 250
# Set up the dataset.
delta_timestamps = {
# Set up the the policy.
cfg = DiffusionConfig()
policy = DiffusionPolicy(cfg, dataset_stats=dataset.meta.stats)
policy.train()
policy.to(device)
dataset,
num_workers=4,
batch_size=64,
shuffle=True,
drop_last=True,
# Run training loop.
step = 0
done = False
while not done:
for batch in dataloader:
loss = output_dict["loss"]
loss.backward()
optimizer.step()
optimizer.zero_grad()
if step % log_freq == 0:
step += 1
if step >= training_steps:
done = True
break
# Save a policy checkpoint.
