Alexander Soare a4891095e4
Use PytorchModelHubMixin to save models as safetensors (#125)
2024-05-01 16:17:18 +01:00
76 lines
2.5 KiB
import os
training_steps = 5000
device = torch.device("cuda")
log_freq = 250
# Set up the dataset.
# Set up the the policy.
cfg = DiffusionConfig()
policy = DiffusionPolicy(cfg, dataset_stats=dataset.stats)
policy.train()
policy.to(device)
dataset,
num_workers=4,
batch_size=64,
shuffle=True,
drop_last=True,
# Run training loop.
step = 0
done = False
while not done:
for batch in dataloader:
loss = output_dict["loss"]
loss.backward()
optimizer.step()
optimizer.zero_grad()
if step % log_freq == 0:
step += 1
if step >= training_steps:
done = True
break
# Save the policy.
# Save the Hydra configuration so we have the environment configuration for eval.
