Julien Perez fab037f78d
feat for the GPU poors : Add GPU availability check in evaluate_pretr… (#359)
2024-08-13 16:03:05 +01:00
121 lines
4.0 KiB
import gym_pusht # noqa: F401
import gymnasium as gym
import imageio
import numpy
# Check if GPU is available
if torch.cuda.is_available():
device = torch.device("cuda")
print("GPU is available. Device set to:", device)
else:
device = torch.device("cpu")
print(f"GPU is not available. Device set to: {device}. Inference will be slower than on GPU.")
# Decrease the number of reverse-diffusion steps (trades off a bit of quality for 10x speed)
policy.diffusion.num_inference_steps = 10
# Download the diffusion policy for pusht environment
pretrained_policy_path = Path(snapshot_download("lerobot/diffusion_pusht"))
policy.eval()
policy.to(device)
env = gym.make(
"gym_pusht/PushT-v0",
obs_type="pixels_agent_pos",
max_episode_steps=300,
# Reset the policy and environmens to prepare for rollout
policy.reset()
rewards = []
frames = []
frames.append(env.render())
step = 0
done = False
while not done:
# to channel last in [0,1]
state = state.unsqueeze(0)
image = image.unsqueeze(0)
observation = {
"observation.state": state,
"observation.image": image,
with torch.inference_mode():
rewards.append(reward)
step += 1
if terminated:
print("Success!")
else:
print("Failure!")
