Lerobot/examples/3_evaluate_pretrained_policy.py
Remi e760e4cd63
Move normalization to policy for act and diffusion (#90)
2024-04-25 11:47:38 +02:00
39 lines
1.2 KiB
# TODO(alexander-soare): This no longer works until we upload a new model that uses the current configs.
# folder = Path("outputs/train/example_pusht_diffusion")
overrides = [
"eval_episodes=10",
"rollout_batch_size=10",
"device=cuda",
# Create a Hydra config.
eval(
cfg,
