Simon Alibert 32eb0cec8f
Dataset v2.0 (#461)
2024-11-29 19:04:00 +01:00
13 KiB
Source the parts
Install LeRobot
On your computer:
  1. Install Miniconda:
mkdir -p ~/miniconda3
rm ~/miniconda3/miniconda.sh
  1. Clone LeRobot:
Configure the motors
Reconnect the usb cable.
sudo chmod 666 /dev/ttyACM0
sudo chmod 666 /dev/ttyACM1
  --brand feetech \
  --model sts3215 \
  --baudrate 1000000 \
  --ID 1
  --brand feetech \
  --model sts3215 \
  --ID 2
Assemble the arms
Calibrate
    --robot-path lerobot/configs/robot/moss.yaml \
Teleoperate
    --display-cameras 0
Record a dataset
    --fps 30 \
    --tags moss tutorial \
    --warmup-time-s 5 \
    --episode-time-s 40 \
    --reset-time-s 10 \
    --num-episodes 2 \
    --push-to-hub 1
Visualize a dataset
echo ${HF_USER}/moss_test
  --repo-id ${HF_USER}/moss_test
Replay an episode
    --fps 30 \
    --episode 0
Train a policy
  dataset_repo_id=${HF_USER}/moss_test \
  policy=act_moss_real \
  env=moss_real \
  hydra.run.dir=outputs/train/act_moss_test \
  hydra.job.name=act_moss_test \
  device=cuda \
Let's explain it:
  1. We provided the dataset as argument with dataset_repo_id=${HF_USER}/moss_test.
  2. We provided the policy with policy=act_moss_real. This loads configurations from lerobot/configs/policy/act_moss_real.yaml. Importantly, this policy uses 2 cameras as input laptop, phone.
  3. We provided an environment as argument with env=moss_real. This loads configurations from lerobot/configs/env/moss_real.yaml.
Evaluate your policy
  --fps 30 \
  --repo-id ${HF_USER}/eval_act_moss_test \
  --tags moss tutorial eval \
  --warmup-time-s 5 \
  --reset-time-s 10 \
  --num-episodes 10 \
  -p outputs/train/act_moss_test/checkpoints/last/pretrained_model
  1. There is an additional -p argument which indicates the path to your policy checkpoint with (e.g. -p outputs/train/eval_moss_test/checkpoints/last/pretrained_model). You can also use the model repository if you uploaded a model checkpoint to the hub (e.g. -p ${HF_USER}/act_moss_test).
  2. The name of dataset begins by eval to reflect that you are running inference (e.g. --repo-id ${HF_USER}/eval_act_moss_test).
More
