2025-03-27 09:55:06 +01:00
6.2 KiB
Setup
  • tethered setup
  • untethered setup
Install LeRobot
  1. Install Miniconda:
mkdir -p ~/miniconda3
rm ~/miniconda3/miniconda.sh
    PATH="$HOME/.local/bin:$PATH"
fi
  1. Clone LeRobot:
cd ~/lerobot && pip install --no-binary=av -e ".[stretch]"
stretch_system_check.py
Model = Stretch 3
Tool = DexWrist 3 w/ Gripper
---- Checking Hardware ----
[Pass] Comms are ready
[Pass] Actuators are ready
---- Checking Software ----
[Pass] Ubuntu 22.04 is ready
[Pass] Firmware is up-to-date
[Pass] ROS2 Humble is ready
    --robot.type=stretch \
    --control.type=calibrate
Note: If you run any of the LeRobot scripts below and Stretch is not properly homed, it will automatically home/calibrate first.
    --control.type=teleoperate
Record one episode:
  --control.type=record \
  --control.fps=30 \
  --control.repo_id=${HF_USER}/stretch_test \
  --control.warmup_time_s=5 \
  --control.episode_time_s=30 \
  --control.reset_time_s=30 \
  --control.num_episodes=2 \
  --control.push_to_hub=true
  --control.type=replay \
  --control.fps=30 \
  --control.episode=0
