24 KiB
Table of Contents
- A. Source the parts
- B. Install software Pi
- C. Setup LeRobot laptop/pc
- D. Assemble the arms
- E. Calibrate
- F. Teleoperate
- G. Record a dataset
- H. Visualize a dataset
- I. Replay an episode
- J. Train a policy
- K. Evaluate your policy
Tip
If you have any questions or need help, please reach out on Discord in the channel
#mobile-so-100-arm.
A. Source the parts
Wired version
B. Install software on Pi
Install OS
Setup SSH
Install LeRobot
On your Raspberry Pi:
1. Install Miniconda:
2. Restart shell
Video install instructions
4. Clone LeRobot:
C. Install LeRobot on laptop
Tip
On your computer:
2. Restart shell
4. Clone LeRobot:
Great 🤗! You are now done installing LeRobot and we can begin assembling the SO100 arms and Mobile base 🤖.
Every time you now want to use LeRobot you can go to the ~/lerobot folder where we installed LeRobot and run one of the commands.
D. Assembly
SO100 Arms
Configure motors
Assemble arms
Mobile base (LeKiwi)
Update config
Video finding port
b. Example outputs
Reconnect the usb cable.
c. Troubleshooting
sudo chmod 666 /dev/ttyACM0
sudo chmod 666 /dev/ttyACM1
d. Update config file
@dataclass
# Network Configuration
ip: str = "172.17.133.91"
port: int = 5555
video_port: int = 5556
default_factory=lambda: {
motors={
# name: (index, model)
"elbow_flex": [3, "sts3215"],
"wrist_flex": [4, "sts3215"],
"wrist_roll": [5, "sts3215"],
"gripper": [6, "sts3215"],
port="/dev/ttyACM0",
motors={
"left_wheel": (7, "sts3215"),
"back_wheel": (8, "sts3215"),
# Movement
"forward": "w",
"backward": "s",
"left": "a",
"right": "d",
"rotate_left": "z",
"rotate_right": "x",
# Speed control
"speed_up": "r",
"speed_down": "f",
# quit teleop
"quit": "q",
mock: bool = False
Wired version
@dataclass
ip: str = "127.0.0.1"
port: int = 5555
"front": OpenCVCameraConfig(
"wrist": OpenCVCameraConfig(
motors={
motors={
# Movement
"forward": "w",
"backward": "s",
"left": "a",
"right": "d",
"rotate_left": "z",
# Speed control
"speed_up": "r",
"speed_down": "f",
# quit teleop
"quit": "q",
mock: bool = False
E. Calibration
Important
| 1. Zero position | 2. Rotated position | 3. Rest position |
--robot.type=lekiwi \
--robot.cameras='{}' \
--control.type=calibrate \
Wired version
Calibrate leader arm
F. Teleoperate
--control.type=remote_robot
--control.type=teleoperate \
--control.fps=30
| Speed Mode | Linear Speed (m/s) | Rotation Speed (deg/s) |
| Fast | 0.4 | 90 |
| Medium | 0.25 | 60 |
| Slow | 0.1 | 30 |
| Key | Action |
| W | Move forward |
| A | Move left |
| S | Move backward |
| D | Move right |
| Z | Turn left |
| X | Turn right |
| R | Increase speed |
| F | Decrease speed |
Tip
If you use a different keyboard you can change the keys for each command in the
LeKiwiRobotConfig.
Wired version
Troubleshoot communication
hostname -I
ping <your_pi_ip_address>
If the ping fails:
- Ensure the Pi is powered on and connected to the same network.
- Check if SSH is enabled on the Pi.
3. Try SSH connection
- Ensure SSH is enabled on the Pi by running:
Then navigate to: Interfacing Options -> SSH and enable it.sudo raspi-config
4. Same config file
G. Record a dataset
--control.type=record \
--control.fps=30 \
--control.warmup_time_s=5 \
--control.episode_time_s=30 \
--control.reset_time_s=30 \
--control.num_episodes=2 \
--control.push_to_hub=true
Wired version
echo ${HF_USER}/lekiwi_test
--local-files-only 1
--control.type=replay \
--control.fps=30 \
--control.episode=0
J. Train a policy
--policy.type=act \
--job_name=act_lekiwi_test \
--device=cuda \
--wandb.enable=true
Let's explain it:
- We provided the dataset as argument with
--dataset.repo_id=${HF_USER}/lekiwi_test. - We provided the policy with
policy.type=act. This loads configurations fromconfiguration_act.py. Importantly, this policy will automatically adapt to the number of motor sates, motor actions and cameras of your robot (e.g.laptopandphone) which have been saved in your dataset. - We provided
device=cudasince we are training on a Nvidia GPU, but you could usedevice=mpsto train on Apple silicon. - We provided
wandb.enable=trueto use Weights and Biases for visualizing training plots. This is optional but if you use it, make sure you are logged in by runningwandb login.
--control.fps=30 \
--control.num_episodes=10 \
--control.push_to_hub=true \
- There is an additional
--control.policy.pathargument which indicates the path to your policy checkpoint with (e.g.outputs/train/eval_act_lekiwi_test/checkpoints/last/pretrained_model). You can also use the model repository if you uploaded a model checkpoint to the hub (e.g.${HF_USER}/act_lekiwi_test). - The name of dataset begins by
evalto reflect that you are running inference (e.g.${HF_USER}/eval_act_lekiwi_test).
