Remi 429a463aff
Control aloha robot natively (#316)
2024-09-04 19:28:05 +02:00
50 KiB
Raw Blame History
What You'll Learn:
First, install the additional dependencies required for robots built with dynamixel motors like Koch v1.1 by running one of the following commands.
Using pip:
pip install -e ".[dynamixel]"
Or using poetry:
Copy pasting python code
It will automatically:
Reconnect the usb cable.
sudo chmod 666 /dev/ttyACM0
sudo chmod 666 /dev/ttyACM1
    port=leader_port,
    motors={
        # name: (index, model)
        "gripper": (6, "xl330-m077"),
    port=follower_port,
    motors={
        "gripper": (6, "xl330-m288"),
robot_type: koch
leader_arms:
  main:
    motors:
      elbow_flex: [3, "xl330-m077"]
      wrist_flex: [4, "xl330-m077"]
      wrist_roll: [5, "xl330-m077"]
      gripper: [6, "xl330-m077"]
follower_arms:
  main:
    motors:
      elbow_flex: [3, "xl330-m288"]
      wrist_flex: [4, "xl330-m288"]
      wrist_roll: [5, "xl330-m288"]
      gripper: [6, "xl330-m288"]
leader_arm.connect()
1. Unplug the power cord
3. Re-plug the power cord
Press Enter to continue...
*Follow the procedure*
follower_arm.connect()
Troubleshooting:
Known failure modes:
Steps:
  3. Launch the software.
  5. For each motor in turn:
print(leader_pos)
print(follower_pos)
# Get the current position
position[0] += 10
position -= 30
# Update gripper by +30 steps
position[-1] += 30
Finally, disconnect the arms:
leader_arm.disconnect()
follower_arm.disconnect()
robot = ManipulatorRobot(
    robot_type="koch",
robot.connect()
Connecting main follower arm
Connecting main leader arm
Move arm to zero position
Move arm to rotated position
Move arm to rest position
Verifying Calibration
print(leader_pos)
print(follower_pos)
Example output:
Teleoperate your Koch v1.1
import tqdm
seconds = 30
frequency = 200
Run this code to teleoperate:
    robot.teleop_step()
print(follower_pos)
print(observation)
print(leader_pos)
print(action)
Expected output:
Asynchronous Frame Recording
Disconnecting the Robot
robot.disconnect()
v4l2-ctl --list-devices
You should see an entry like:
/dev/video1
>>> Format Video Capture:
Instantiate an OpenCVCamera
Camera found at index 0
Camera found at index 1
Connecting cameras
camera.connect()
color_image = camera.read()
print(color_image.shape)
print(color_image.dtype)
(1080, 1920, 3)
uint8
(480, 640, 3)
uint8
Disconnecting the camera
camera.disconnect()
    cameras={
robot.connect()
torch.Size([3, 480, 640])
cameras:
  laptop:
    camera_index: 0
    fps: 30
    width: 640
    height: 480
  phone:
    camera_index: 1
    fps: 30
    width: 640
    height: 480
It contains
  --robot-overrides \
  --robot-overrides \
    '~cameras'
import time
record_time_s = 30
fps = 60
states = []
actions = []
    busy_wait(1 / fps - dt_s)
  --fps 30 \
  --root data \
  --tags tutorial \
  --warmup-time-s 5 \
  --episode-time-s 30 \
  --reset-time-s 30 \
  --num-episodes 2
It contains:
Troubleshooting:
pip uninstall opencv-python
c. Visualize all episodes
  --root data \
  --fps 30 \
  --root data \
  --episode 0
a. Use the train script
  policy=act_koch_real \
  env=koch_real \
  device=cuda \
Let's explain it:
override_dataset_stats:
  observation.images.laptop:
  observation.images.phone:
  input_shapes:
  input_normalization_modes:
fps: 30
env:
  task: null
  state_dim: 6
  action_dim: 6
  fps: ${fps}
CKPT=010000
5. Evaluate your policy
inference_time_s = 60
fps = 30
policy.to(device)
    # with batch dimension
    for name in observation:
        if "image" in name:
    # Remove batch dimension
    action = action.squeeze(0)
    action = action.to("cpu")
    # Order the robot to move
    robot.send_action(action)
  --fps 30 \
  --root data \
  --tags tutorial eval \
  --warmup-time-s 5 \
  --reset-time-s 30 \
  --num-episodes 10 \
  --root data \
6. Next step
