Remi 07e8716315
Add FeetechMotorsBus, SO-100, Moss-v1 (#419)
Co-authored-by: jess-moss <jess.moss@huggingface.co>
2024-10-25 11:23:55 +02:00
6.3 KiB
Setup
  • tethered setup
  • untethered setup
Install LeRobot
  1. Install Miniconda:
mkdir -p ~/miniconda3
rm ~/miniconda3/miniconda.sh
    PATH="$HOME/.local/bin:$PATH"
fi
  1. Clone LeRobot:
stretch_system_check.py
Model = Stretch 3
Tool = DexWrist 3 w/ Gripper
---- Checking Hardware ----
[Pass] Comms are ready
[Pass] Actuators are ready
---- Checking Software ----
[Pass] Ubuntu 22.04 is ready
[Pass] Firmware is up-to-date
[Pass] ROS2 Humble is ready
    --robot-path lerobot/configs/robot/stretch.yaml
Note: If you run any of the LeRobot scripts below and Stretch is not poperly homed, it will automatically home/calibrate first.
Record one episode:
    --robot-path lerobot/configs/robot/stretch.yaml \
    --fps 20 \
    --root data \
    --repo-id ${HF_USER}/stretch_test \
    --tags stretch tutorial \
    --warmup-time-s 3 \
    --episode-time-s 40 \
    --reset-time-s 10 \
    --num-episodes 1 \
    --push-to-hub 0
    --fps 20 \
    --root data \
    --episode 0
