Simon Alibert 32eb0cec8f
Dataset v2.0 (#461)
2024-11-29 19:04:00 +01:00
13 KiB
This tutorial explains how to use SO-100 with LeRobot.
Source the parts
Install LeRobot
On your computer:
  1. Install Miniconda:
mkdir -p ~/miniconda3
rm ~/miniconda3/miniconda.sh
  1. Clone LeRobot:
Configure the motors
Reconnect the usb cable.
sudo chmod 666 /dev/ttyACM0
sudo chmod 666 /dev/ttyACM1
  --brand feetech \
  --model sts3215 \
  --baudrate 1000000 \
  --ID 1
  --brand feetech \
  --model sts3215 \
  --ID 2
Add motor horn to the motors Follow step 3 of the assembly video. For SO-100, you need to align the holes on the motor horn to the motor spline to be approximately 1:30, 4:30, 7:30 and 10:30. Try to avoid rotating the motor while doing so to keep position 2048 set during configuration. It is especially tricky for the leader motors as it is more sensible without the gears, but it's ok if it's a bit rotated.
Assemble the arms
Calibrate
    --robot-path lerobot/configs/robot/so100.yaml \
Teleoperate
    --display-cameras 0
Record a dataset
    --fps 30 \
    --tags so100 tutorial \
    --warmup-time-s 5 \
    --episode-time-s 40 \
    --reset-time-s 10 \
    --num-episodes 2 \
    --push-to-hub 1
Visualize a dataset
echo ${HF_USER}/so100_test
  --repo-id ${HF_USER}/so100_test
Replay an episode
    --fps 30 \
    --episode 0
Train a policy
  dataset_repo_id=${HF_USER}/so100_test \
  policy=act_so100_real \
  env=so100_real \
  hydra.run.dir=outputs/train/act_so100_test \
  hydra.job.name=act_so100_test \
  device=cuda \
Let's explain it:
  1. We provided the dataset as argument with dataset_repo_id=${HF_USER}/so100_test.
  2. We provided the policy with policy=act_so100_real. This loads configurations from lerobot/configs/policy/act_so100_real.yaml. Importantly, this policy uses 2 cameras as input laptop, phone.
  3. We provided an environment as argument with env=so100_real. This loads configurations from lerobot/configs/env/so100_real.yaml.
Evaluate your policy
  --fps 30 \
  --repo-id ${HF_USER}/eval_act_so100_test \
  --tags so100 tutorial eval \
  --warmup-time-s 5 \
  --reset-time-s 10 \
  --num-episodes 10 \
  -p outputs/train/act_so100_test/checkpoints/last/pretrained_model
  1. There is an additional -p argument which indicates the path to your policy checkpoint with (e.g. -p outputs/train/eval_so100_test/checkpoints/last/pretrained_model). You can also use the model repository if you uploaded a model checkpoint to the hub (e.g. -p ${HF_USER}/act_so100_test).
  2. The name of dataset begins by eval to reflect that you are running inference (e.g. --repo-id ${HF_USER}/eval_act_so100_test).
More
If you have any question or need help, please reach out on Discord in the channel #so100-arm.
