2025-02-25 23:51:15 +01:00
50 KiB
Raw Blame History
What You'll Learn:
Using pip:
pip install -e ".[dynamixel]"
Using poetry:
Using uv:
uv sync --extra "dynamixel"
pip uninstall opencv-python
  --robot.type=koch \
  --control.type=teleoperate
It will automatically:
  --brand dynamixel \
  --model xl330-m288 \
  --baudrate 1000000 \
  --ID 1
  --brand dynamixel \
  --ID 2
Reconnect the usb cable.
    motors={
        # name: (index, model)
        "gripper": (6, "xl330-m077"),
    motors={
        "gripper": (6, "xl330-m288"),
@dataclass
        default_factory=lambda: {
                motors={
                    "gripper": [6, "xl330-m077"],
                motors={
                    "gripper": [6, "xl330-m288"],
leader_arm.connect()
1. Unplug the power cord
3. Re-plug the power cord
Press Enter to continue...
*Follow the procedure*
follower_arm.connect()
Troubleshooting:
Known failure modes:
Steps:
  3. Launch the software.
  5. For each motor in turn:
print(leader_pos)
print(follower_pos)
# Get the current position
position[0] += 10
position -= 30
# Update gripper by +30 steps
position[-1] += 30
Finally, disconnect the arms:
leader_arm.disconnect()
follower_arm.disconnect()
During calibration, we count the number of full 360-degree rotations your motors have made since they were first used. That's why we ask yo to move to this arbitrary "zero" position. We don't actually "set" the zero position, so you don't need to be accurate. After calculating these "offsets" to shift the motor values around 0, we need to assess the rotation direction of each motor, which might differ. That's why we ask you to rotate all motors to roughly 90 degrees, to measure if the values changed negatively or positively.
robot.connect()
Connecting main follower arm
Connecting main leader arm
Move arm to zero position
Move arm to rotated position
Move arm to rest position
Verifying Calibration
print(leader_pos)
print(follower_pos)
Example output:
Teleoperate your Koch v1.1
import tqdm
seconds = 30
frequency = 200
Run this code to teleoperate:
    robot.teleop_step()
print(follower_pos)
print(observation)
print(leader_pos)
print(action)
Expected output:
Asynchronous Frame Recording
Disconnecting the Robot
robot.disconnect()
v4l2-ctl --list-devices
You should see an entry like:
/dev/video1
>>> Format Video Capture:
Instantiate an OpenCVCamera
Camera found at index 0
Camera found at index 1
Connecting cameras
camera = OpenCVCamera(config)
camera.connect()
color_image = camera.read()
print(color_image.shape)
print(color_image.dtype)
(1080, 1920, 3)
uint8
(480, 640, 3)
uint8
Disconnecting the camera
camera.disconnect()
robot = ManipulatorRobot(
    KochRobotConfig(
        cameras={
robot.connect()
torch.Size([3, 480, 640])
  --robot.type=koch \
It contains
  --robot.type=koch \
  --robot.cameras='{}' \
import time
record_time_s = 30
fps = 60
states = []
actions = []
    busy_wait(1 / fps - dt_s)
a. Use the record function
  --robot.type=koch \
  --control.type=record \
  --control.fps=30 \
  --control.warmup_time_s=5 \
  --control.episode_time_s=30 \
  --control.reset_time_s=30 \
  --control.num_episodes=2 \
  --control.push_to_hub=true
It contains:
Troubleshooting:
c. Visualize all episodes
  --robot.type=koch \
  --control.type=replay \
  --control.fps=30 \
  --control.episode=0
a. Use the train script
  --policy.type=act \
  --job_name=act_koch_test \
  --device=cuda \
  --wandb.enable=true
Let's explain it:
CKPT=010000
5. Evaluate your policy
inference_time_s = 60
fps = 30
policy.to(device)
    # with batch dimension
    for name in observation:
        if "image" in name:
    # Remove batch dimension
    action = action.squeeze(0)
    action = action.to("cpu")
    # Order the robot to move
    robot.send_action(action)
a. Use our record function
  --robot.type=koch \
  --control.fps=30 \
  --control.num_episodes=10 \
  --control.push_to_hub=true \
6. Next step
