Simon Alibert 90e099b39f
Remove offline training, refactor train.py and logging/checkpointing (#670)
2025-02-11 10:36:06 +01:00
107 lines
4.4 KiB
from lerobot.common.datasets.utils import dataset_to_policy_features
from lerobot.configs.types import FeatureType
def main():
# # Select your device
device = torch.device("cuda")
training_steps = 5000
log_freq = 1
# When starting from scratch (i.e. not from a pretrained policy), we need to specify 2 things before
# creating the policy:
# - input/output shapes: to properly size the policy
# - dataset stats: for normalization and denormalization of input/outputs
dataset_metadata = LeRobotDatasetMetadata("lerobot/pusht")
features = dataset_to_policy_features(dataset_metadata.features)
output_features = {key: ft for key, ft in features.items() if ft.type is FeatureType.ACTION}
input_features = {key: ft for key, ft in features.items() if key not in output_features}
# Policies are initialized with a configuration class, in this case `DiffusionConfig`. For this example,
# we'll just use the defaults and so no arguments other than input/output features need to be passed.
cfg = DiffusionConfig(input_features=input_features, output_features=output_features)
# We can now instantiate our policy with this config and the dataset stats.
policy = DiffusionPolicy(cfg, dataset_stats=dataset_metadata.stats)
policy.train()
policy.to(device)
# Another policy-dataset interaction is with the delta_timestamps. Each policy expects a given number frames
# which can differ for inputs, outputs and rewards (if there are some).
delta_timestamps = {
"observation.image": [i / dataset_metadata.fps for i in cfg.observation_delta_indices],
"observation.state": [i / dataset_metadata.fps for i in cfg.observation_delta_indices],
"action": [i / dataset_metadata.fps for i in cfg.action_delta_indices],
# In this case with the standard configuration for Diffusion Policy, it is equivalent to this:
# We can then instantiate the dataset with these delta_timestamps configuration.
# Then we create our optimizer and dataloader for offline training.
dataset,
num_workers=4,
batch_size=64,
shuffle=True,
pin_memory=device.type != "cpu",
drop_last=True,
# Run training loop.
step = 0
done = False
while not done:
for batch in dataloader:
loss, _ = policy.forward(batch)
loss.backward()
optimizer.step()
optimizer.zero_grad()
if step % log_freq == 0:
step += 1
if step >= training_steps:
done = True
break
# Save a policy checkpoint.
if __name__ == "__main__":
main()
