Lerobot/examples/12_use_so101.md
2025-05-05 10:35:32 +02:00
36 KiB
Raw Blame History
Assemble and use SO-101
In the steps below we explain how to assemble and use our flagship robot, the SO-101 with LeRobot 🤗.
Source the parts
Install LeRobot
Tip
Now restart the shell by running:
Windows:
`source ~/.bashrc`
Mac:
`source ~/.bash_profile`
zshell:
`source ~/.zshrc`
Then activate your conda environment, you have to do this each time you open a shell to use lerobot:
Note
This usually installs ffmpeg 7.X for your platform compiled with the libsvtav1 encoder. If libsvtav1 is not supported (check supported encoders with ffmpeg -encoders), you can:
cd lerobot && pip install ".[feetech]"
Note
If you encounter build errors, you may need to install additional dependencies (cmake, build-essential, and ffmpeg libs). On Linux, run: sudo apt-get install cmake build-essential python3-dev pkg-config libavformat-dev libavcodec-dev libavdevice-dev libavutil-dev libswscale-dev libswresample-dev libavfilter-dev pkg-config. For other systems, see: Compiling PyAV
Configure motors
To configure the motors designate one bus servo adapter and 6 motors for your leader arm, and similarly the other bus servo adapter and 6 motors for the follower arm. It's convenient to label them and write on each motor if it's for the follower F or for the leader L and it's ID from 1 to 6.
You now should plug the 5V or 12V power supply to the motor bus. 5V for the STS3215 7.4V motors and 12V for the STS3215 12V motors. Note that the leader arm always uses the 7.4V motors, so watch out that you plug in the right power supply if you have 12V and 7.4V motors, otherwise you might burn your motors! Now, connect the motor bus to your computer via USB. Note that the USB doesn't provide any power, and both the power supply and USB have to be plugged in.
Find the USB ports associated to each arm
To find the port for each bus servo adapter, run this script:
Example outputs of script
Mac:
Example output leader arm's port: /dev/tty.usbmodem575E0031751
Reconnect the usb cable.
Example output follower arm port: /dev/tty.usbmodem575E0032081
Linux:
sudo chmod 666 /dev/ttyACM0
sudo chmod 666 /dev/ttyACM1
Example output leader arm port: /dev/ttyACM0
['/dev/ttyACM0', '/dev/ttyACM1']
The port of this MotorsBus is /dev/ttyACM0
Example output follower arm port: /dev/ttyACM1
The port of this MotorsBus is /dev/ttyACM1
Update config file
Now that you have your ports, update the port default values of SO101RobotConfig. You will find something a class called so101 where you can update the port values with your actual motor ports:
@RobotConfig.register_subclass("so101")
@dataclass
class So101RobotConfig(ManipulatorRobotConfig):
    calibration_dir: str = ".cache/calibration/so101"
        default_factory=lambda: {
                motors={
                    # name: (index, model)
                    "elbow_flex": [3, "sts3215"],
                    "wrist_flex": [4, "sts3215"],
                    "wrist_roll": [5, "sts3215"],
                    "gripper": [6, "sts3215"],
                motors={
Here is a video of the process:
Set motor IDs
Now we need to set the motor ID for each motor. Plug your motor in only one of the two ports of the motor bus and run this script to set its ID to 1. Replace the text after --port to the corresponding control board port.
  --brand feetech \
  --model sts3215 \
  --baudrate 1000000 \
  --ID 1
  --brand feetech \
  --model sts3215 \
  --ID 2
Redo this process for all your motors until ID 6. Do the same for the 6 motors of the leader arm, but make sure to change the power supply if you use motors with different voltage.
Step-by-Step Assembly Instructions
The follower arm uses 6x STS3215 motors with 1/345 gearing. The leader however uses three differently geared motors to make sure it can both sustain its own weight and it can be moved without requiring much force. Which motor is needed for which joint is shown in table below.
Leader-Arm Axis Motor Gear Ratio
Base / Shoulder Yaw 1 1 / 191
Shoulder Pitch 2 1 / 345
Elbow 3 1 / 191
Wrist Roll 4 1 / 147
Wrist Pitch 5 1 / 147
Gripper 6 1 / 147
Clean Parts
Remove all support material from the 3D-printed parts.
Joint 1
  • Fasten the motor with 4 M2x6mm screws (smallest screws). Two from the top and two from bottom.
  • Slide over the first motor holder and fasten it using two M2x6mm screws (one on each side).
  • Install both motor horns, securing the top horn with a M3x6mm screw.
  • Attach the shoulder part.
  • Tighten the shoulder part with 4 M3x6mm screws on top and 4 M3x6mm screws on the bottom
Joint 2
  • Slide the second motor in from the top.
  • Fasten the second motor with 4 M2x6mm screws.
  • Attach both motor horns to motor 2, again use the M3x6mm horn screw.
  • Attach the upper arm with 4 M3x6mm screws on each side.
Joint 3
  • Insert motor 3 and fasten using 4 M2x6mm screws
  • Attach both motor horns to motor 3 and secure one again with a M3x6mm horn screw.
  • Connect the forearm to motor 3 using 4 M3x6mm screws on each side.
Joint 4
  • Slide over motor holder 4.
  • Slide in motor 4.
  • Fasten motor 4 with 4 M2x6mm screws and attach its motor horns, use a M3x6mm horn screw.
Joint 5
  • Insert motor 5 into the wrist holder and secure it with 2 M2x6mm front screws.
  • Install only one motor horn on the wrist motor and secure it with a M3x6mm horn screw.
  • Secure the wrist to motor 4 using 4 M3x6mm screws on both sides.
Gripper / Handle
Follower:
  • Attach the gripper to motor 5, attach it to the motor horn on the wrist using 4 M3x6mm screws.
  • Insert the gripper motor and secure it with 2 M2x6mm screws on each side.
  • Attach the motor horns and again use a M3x6mm horn screw.
  • Install the gripper claw and secure it with 4 M3x6mm screws on both sides.
Leader:
  • Mount the leader holder onto the wrist and secure it with 4 M3x6mm screws.
  • Attach the handle to motor 5 using 1 M2x6mm screw.
  • Insert the gripper motor, secure it with 2 M2x6mm screws on each side, attach a motor horn using a M3x6mm horn screw.
  • Attach the follower trigger with 4 M3x6mm screws.
Wiring
  • Then insert all wires, use the wire guides everywhere to make sure the wires don't unplug themself and stay in place.
Calibrate
Next, you'll need to calibrate your SO-101 robot to ensure that the leader and follower arms have the same position values when they are in the same physical position. The calibration process is very important because it allows a neural network trained on one SO-101 robot to work on another.
Manual calibration of follower arm
You will need to move the follower arm to these positions sequentially, note that the rotated position is on the right side of the robot and you have to open the gripper fully.
1. Middle position 2. Zero position 3. Rotated position 4. Rest position
SO-101 leader arm middle position SO-101 leader arm zero position SO-101 leader arm rotated position SO-101 leader arm rest position
  --robot.type=so101 \
  --robot.cameras='{}' \
  --control.type=calibrate \
Manual calibration of leader arm
You will also need to move the leader arm to these positions sequentially:
Control your robot
Congrats 🎉, your robot is all set to learn a task on its own. Next we will explain you how to train a neural network to autonomously control a real robot.
You'll learn to:
  1. How to record and visualize your dataset.
  2. How to train a policy using your data and prepare it for evaluation.
  3. How to evaluate your policy and visualize the results.
This tutorial is specifically made for the affordable SO-101 robot, but it contains additional information to be easily adapted to various types of robots like Aloha bimanual robot by changing some configurations. The SO-101 consists of a leader arm and a follower arm, each with 6 motors. It can work with one or several cameras to record the scene, which serve as visual sensors for the robot.
If you encounter any issues at any step of the tutorial, feel free to seek help on Discord or don't hesitate to iterate with us on the tutorial by creating issues or pull requests.
Teleoperate
Run this simple script to teleoperate your robot (it won't connect and display the cameras):
  --control.type=teleoperate
The teleoperate command will automatically:
Setup Cameras
To connect a camera you have three options:
  1. OpenCVCamera which allows us to use any camera: usb, realsense, laptop webcam
  2. iPhone camera with MacOS
  3. Phone camera on Linux
Use OpenCVCamera
Camera found at index 0
Camera found at index 1
Connecting cameras
Frame: 0000 Latency (ms): 39.52
Frame: 0046 Latency (ms): 40.07
Now that you have the camera indexes, you should change them in the config. You can also change the fps, width or height of the camera.
The camera config is defined per robot, can be found here RobotConfig and looks like this:
            "wrist": OpenCVCameraConfig(
                camera_index=0,  <-- UPDATE HERE
                fps=30,
                width=640,
                height=480,
            "base": OpenCVCameraConfig(
                camera_index=1,   <-- UPDATE HERE
                fps=30,
                width=640,
                height=480,
Use your phone
Mac:
Linux:
v4l2-ctl --list-devices
You should see an entry like:
/dev/video1
>>> Format Video Capture:
>>> Width/Height      : 640/480
>>> Pixel Format      : 'YUYV' (YUYV 4:2:2)
Add wrist camera
If you have an additional camera you can add a wrist camera to the SO101. There are already many premade wrist camera holders that you can find in the SO101 repo: Wrist camera's
Teleoperate with cameras
We can now teleoperate again while at the same time visualizing the camera's and joint positions with rerun.
  --control.type=teleoperate \
  --control.display_data=true
Record a dataset
We use the Hugging Face hub features for uploading your dataset. If you haven't previously used the Hub, make sure you can login via the cli using a write-access token, this token can be generated from the Hugging Face settings.
Add your token to the cli by running this command:
Then store your Hugging Face repository name in a variable:
Now you can record a dataset, to record 2 episodes and upload your dataset to the hub execute this command:
  --control.type=record \
  --control.fps=30 \
  --control.repo_id=${HF_USER}/so101_test \
  --control.tags='["so101","tutorial"]' \
  --control.warmup_time_s=5 \
  --control.episode_time_s=30 \
  --control.reset_time_s=30 \
  --control.num_episodes=2 \
  --control.display_data=true \
  --control.push_to_hub=true
It contains:
Dataset upload
Locally your dataset is stored in this folder: ~/.cache/huggingface/lerobot/{repo-id} (e.g. data/cadene/so101_test). At the end of data recording, your dataset will be uploaded on your Hugging Face page (e.g. https://huggingface.co/datasets/cadene/so101_test) that you can obtain by running:
echo https://huggingface.co/datasets/${HF_USER}/so101_test
Your dataset will be automatically tagged with LeRobot for the community to find it easily, and you can also add custom tags (in this case tutorial for example).
You can look for other LeRobot datasets on the hub by searching for LeRobot tags.
Record function
The record function provides a suite of tools for capturing and managing data during robot operation:
  1. Set the flow of data recording using command line arguments:
  2. Control the flow during data recording using keyboard keys:
  3. Checkpoints are done set during recording, so if any issue occurs, you can resume recording by re-running the same command again with --control.resume=true. You will need to manually delete the dataset directory if you want to start recording from scratch.
Tips for gathering data
Once you're comfortable with data recording, you can create a larger dataset for training. A good starting task is grasping an object at different locations and placing it in a bin. We suggest recording at least 50 episodes, with 10 episodes per location. Keep the cameras fixed and maintain consistent grasping behavior throughout the recordings. Also make sure the object you are manipulating is visible on the camera's. A good rule of thumb is you should be able to do the task yourself by only looking at the camera images.
Troubleshooting:
Visualize a dataset
echo ${HF_USER}/so101_test
If you didn't upload with --control.push_to_hub=false, you can visualize it locally with (via a window in the browser http://127.0.0.1:9090 with the visualization tool):
  --repo-id ${HF_USER}/so101_test \
  --local-files-only 1
Replay an episode
A useful feature is the replay function, which allows to replay on your robot any episode that you've recorded or episodes from any dataset out there. This function helps you test the repeatability of your robot's actions and assess transferability across robots of the same model.
You can replay the first episode on your robot with:
  --control.type=replay \
  --control.fps=30 \
  --control.episode=0
Train a policy
  --dataset.repo_id=${HF_USER}/so101_test \
  --policy.type=act \
  --output_dir=outputs/train/act_so101_test \
  --job_name=act_so101_test \
  --policy.device=cuda \
  --wandb.enable=true
Let's explain the command:
  1. We provided the dataset as argument with --dataset.repo_id=${HF_USER}/so101_test.
Training should take several hours. You will find checkpoints in outputs/train/act_so101_test/checkpoints.
To resume training from a checkpoint, below is an example command to resume from last checkpoint of the act_so101_test policy:
  --config_path=outputs/train/act_so101_test/checkpoints/last/pretrained_model/train_config.json \
  --resume=true
Upload policy checkpoints
huggingface-cli upload ${HF_USER}/act_so101_test \
CKPT=010000
huggingface-cli upload ${HF_USER}/act_so101_test${CKPT} \
  outputs/train/act_so101_test/checkpoints/${CKPT}/pretrained_model
Evaluate your policy
  --control.fps=30 \
  --control.repo_id=${HF_USER}/eval_act_so101_test \
  --control.num_episodes=10 \
  --control.push_to_hub=true \
  --control.policy.path=outputs/train/act_so101_test/checkpoints/last/pretrained_model
  1. There is an additional --control.policy.path argument which indicates the path to your policy checkpoint with (e.g. outputs/train/eval_act_so101_test/checkpoints/last/pretrained_model). You can also use the model repository if you uploaded a model checkpoint to the hub (e.g. ${HF_USER}/act_so101_test).
  2. The name of dataset begins by eval to reflect that you are running inference (e.g. ${HF_USER}/eval_act_so101_test).
