Steven Palma 725b446ad6
fix(deps): constrain PyAV version to resolve OpenCV-python ffmpeg version conflict (#883)
2025-03-24 23:40:22 +01:00
17 KiB
Source the parts
Follow this README. It contains the bill of materials with link to source the parts, as well as the instructions to 3D print the parts and advice if it's your first time printing or if you don't own a 3D printer already.
Install LeRobot
On your computer:
  1. Install Miniconda:
mkdir -p ~/miniconda3
rm ~/miniconda3/miniconda.sh
  1. Clone LeRobot:
Configure the motors
Reconnect the usb cable.
sudo chmod 666 /dev/ttyACM0
sudo chmod 666 /dev/ttyACM1
Update config file
IMPORTANTLY: Now that you have your ports, update the port default values of MossRobotConfig. You will find something like:
@RobotConfig.register_subclass("moss")
@dataclass
class MossRobotConfig(ManipulatorRobotConfig):
    calibration_dir: str = ".cache/calibration/moss"
        default_factory=lambda: {
                motors={
                    # name: (index, model)
                    "elbow_flex": [3, "sts3215"],
                    "wrist_flex": [4, "sts3215"],
                    "wrist_roll": [5, "sts3215"],
                    "gripper": [6, "sts3215"],
                motors={
  --brand feetech \
  --model sts3215 \
  --baudrate 1000000 \
  --ID 1
  --brand feetech \
  --model sts3215 \
  --ID 2
Assemble the arms
Calibrate
  --robot.type=moss \
  --robot.cameras='{}' \
  --control.type=calibrate \
  --robot.type=moss \
Teleoperate
  --robot.type=moss \
  --control.type=teleoperate
  --robot.type=moss \
Record a dataset
  --robot.type=moss \
  --control.type=record \
  --control.fps=30 \
  --control.repo_id=${HF_USER}/moss_test \
  --control.tags='["moss","tutorial"]' \
  --control.warmup_time_s=5 \
  --control.episode_time_s=30 \
  --control.reset_time_s=30 \
  --control.num_episodes=2 \
  --control.push_to_hub=true
Visualize a dataset
echo ${HF_USER}/moss_test
  --local-files-only 1
Replay an episode
  --robot.type=moss \
  --control.type=replay \
  --control.fps=30 \
  --control.episode=0
Train a policy
  --dataset.repo_id=${HF_USER}/moss_test \
  --policy.type=act \
  --output_dir=outputs/train/act_moss_test \
  --job_name=act_moss_test \
  --policy.device=cuda \
  --wandb.enable=true
Let's explain it:
  1. We provided the dataset as argument with --dataset.repo_id=${HF_USER}/moss_test.
Evaluate your policy
  --robot.type=moss \
  --control.fps=30 \
  --control.repo_id=${HF_USER}/eval_act_moss_test \
  --control.num_episodes=10 \
  --control.push_to_hub=true \
  --control.policy.path=outputs/train/act_moss_test/checkpoints/last/pretrained_model
  1. There is an additional --control.policy.path argument which indicates the path to your policy checkpoint with (e.g. outputs/train/eval_act_moss_test/checkpoints/last/pretrained_model). You can also use the model repository if you uploaded a model checkpoint to the hub (e.g. ${HF_USER}/act_moss_test).
  2. The name of dataset begins by eval to reflect that you are running inference (e.g. ${HF_USER}/eval_act_moss_test).
More
