Steven Palma 725b446ad6
fix(deps): constrain PyAV version to resolve OpenCV-python ffmpeg version conflict (#883)
2025-03-24 23:40:22 +01:00
52 KiB
Raw Blame History
What You'll Learn:
Using pip:
pip install -e ".[dynamixel]"
Using poetry:
Using uv:
uv sync --extra "dynamixel"
  --robot.type=koch \
  --control.type=teleoperate
It will automatically:
  --brand dynamixel \
  --model xl330-m288 \
  --baudrate 1000000 \
  --ID 1
  --brand dynamixel \
  --ID 2
Reconnect the usb cable.
    motors={
        # name: (index, model)
        "gripper": (6, "xl330-m077"),
    motors={
        "gripper": (6, "xl330-m288"),
@dataclass
        default_factory=lambda: {
                motors={
                    "gripper": [6, "xl330-m077"],
                motors={
                    "gripper": [6, "xl330-m288"],
leader_arm.connect()
1. Unplug the power cord
3. Re-plug the power cord
Press Enter to continue...
*Follow the procedure*
follower_arm.connect()
Troubleshooting:
Known failure modes:
Steps:
  3. Launch the software.
  5. For each motor in turn:
** There is a common issue with the Dynamixel XL430-W250 motors where the motors become undiscoverable after upgrading their firmware from Mac and Windows Dynamixel Wizard2 applications. When this occurs, it is required to do a firmware recovery (Select DYNAMIXEL Firmware Recovery and follow the prompts). There are two known workarounds to conduct this firmware reset:
  1. Install the Dynamixel Wizard on a linux machine and complete the firmware recovery
  2. Use the Dynamixel U2D2 in order to perform the reset with Windows or Mac. This U2D2 can be purchased here. For either solution, open DYNAMIXEL Wizard 2.0 and select the appropriate port. You will likely be unable to see the motor in the GUI at this time. Select Firmware Recovery, carefully choose the correct model, and wait for the process to complete. Finally, re-scan to confirm the firmware recovery was successful.
print(leader_pos)
print(follower_pos)
# Get the current position
position[0] += 10
position -= 30
# Update gripper by +30 steps
position[-1] += 30
Finally, disconnect the arms:
leader_arm.disconnect()
follower_arm.disconnect()
During calibration, we count the number of full 360-degree rotations your motors have made since they were first used. That's why we ask yo to move to this arbitrary "zero" position. We don't actually "set" the zero position, so you don't need to be accurate. After calculating these "offsets" to shift the motor values around 0, we need to assess the rotation direction of each motor, which might differ. That's why we ask you to rotate all motors to roughly 90 degrees, to measure if the values changed negatively or positively.
robot.connect()
Connecting main follower arm
Connecting main leader arm
Move arm to zero position
Move arm to rotated position
Move arm to rest position
Verifying Calibration
print(leader_pos)
print(follower_pos)
Example output:
Teleoperate your Koch v1.1
import tqdm
seconds = 30
frequency = 200
Run this code to teleoperate:
    robot.teleop_step()
print(follower_pos)
print(observation)
print(leader_pos)
print(action)
Expected output:
Asynchronous Frame Recording
Disconnecting the Robot
robot.disconnect()
v4l2-ctl --list-devices
You should see an entry like:
/dev/video1
>>> Format Video Capture:
Instantiate an OpenCVCamera
Camera found at index 0
Camera found at index 1
Connecting cameras
camera = OpenCVCamera(config)
camera.connect()
color_image = camera.read()
print(color_image.shape)
print(color_image.dtype)
(1080, 1920, 3)
uint8
(480, 640, 3)
uint8
Disconnecting the camera
camera.disconnect()
robot = ManipulatorRobot(
    KochRobotConfig(
        cameras={
robot.connect()
torch.Size([3, 480, 640])
  --robot.type=koch \
It contains
  --robot.type=koch \
  --robot.cameras='{}' \
import time
record_time_s = 30
fps = 60
states = []
actions = []
    busy_wait(1 / fps - dt_s)
a. Use the record function
  --robot.type=koch \
  --control.type=record \
  --control.fps=30 \
  --control.warmup_time_s=5 \
  --control.episode_time_s=30 \
  --control.reset_time_s=30 \
  --control.num_episodes=2 \
  --control.push_to_hub=true
It contains:
Troubleshooting:
c. Visualize all episodes
  --robot.type=koch \
  --control.type=replay \
  --control.fps=30 \
  --control.episode=0
a. Use the train script
  --policy.type=act \
  --job_name=act_koch_test \
  --policy.device=cuda \
  --wandb.enable=true
Let's explain it:
CKPT=010000
5. Evaluate your policy
inference_time_s = 60
fps = 30
policy.to(device)
    # with batch dimension
    for name in observation:
        if "image" in name:
    # Remove batch dimension
    action = action.squeeze(0)
    action = action.to("cpu")
    # Order the robot to move
    robot.send_action(action)
a. Use our record function
  --robot.type=koch \
  --control.fps=30 \
  --control.num_episodes=10 \
  --control.push_to_hub=true \
6. Next step
