Simon Alibert 3354d919fc
LeRobotDataset v2.1 (#711)
Co-authored-by: Remi Cadene <re.cadene@gmail.com>
2025-02-25 15:27:29 +01:00
18 KiB
Using the SO-100 with LeRobot
Table of Contents
A. Source the parts
B. Install LeRobot
Tip
On your computer:
1. Install Miniconda:
2. Restart shell
Video install instructions
4. Clone LeRobot:
Great 🤗! You are now done installing LeRobot and we can begin assembling the SO100 arms 🤖. Every time you now want to use LeRobot you can go to the ~/lerobot folder where we installed LeRobot and run one of the commands.
C. Configure the motors
Note
Throughout this tutorial you will find videos on how to do the steps, the full video tutorial can be found here: assembly video.
Designate one bus servo adapter and 6 motors for your leader arm, and similarly the other bus servo adapter and 6 motors for the follower arm. It's convenient to label them and write on each motor if it's for the follower F or for the leader L and it's ID from 1 to 6 (F1...F6 and L1...L6).
Video finding port
b. Example outputs
Reconnect the usb cable.
c. Troubleshooting
sudo chmod 666 /dev/ttyACM0
sudo chmod 666 /dev/ttyACM1
d. Update config file
@dataclass
        default_factory=lambda: {
                motors={
                    # name: (index, model)
                    "elbow_flex": [3, "sts3215"],
                    "wrist_flex": [4, "sts3215"],
                    "wrist_roll": [5, "sts3215"],
                    "gripper": [6, "sts3215"],
                motors={
2. Assembling the Base
Let's begin with assembling the follower arm base
a. Set IDs for all 12 motors
Video configuring motor
Plug your first motor F1 and run this script to set its ID to 1. It will also set its present position to 2048, so expect your motor to rotate. Replace the text after --port to the corresponding follower control board port and run this command in cmd:
  --brand feetech \
  --model sts3215 \
  --baudrate 1000000 \
  --ID 1
Note
These motors are currently limited. They can take values between 0 and 4096 only, which corresponds to a full turn. They can't turn more than that. 2048 is at the middle of this range, so we can take -2048 steps (180 degrees anticlockwise) and reach the maximum range, or take +2048 steps (180 degrees clockwise) and reach the maximum range. The configuration step also sets the homing offset to 0, so that if you misassembled the arm, you can always update the homing offset to account for a shift up to ± 2048 steps (± 180 degrees).
  --brand feetech \
  --model sts3215 \
  --ID 2
Video removing gears
Follow the video for removing gears. You need to remove the gear for the motors of the leader arm. As a result, you will only use the position encoding of the motor and reduce friction to more easily operate the leader arm.
c. Add motor horn to all 12 motors
Video adding motor horn
Follow the video for adding the motor horn. For SO-100, you need to align the holes on the motor horn to the motor spline to be approximately 1:30, 4:30, 7:30 and 10:30. Try to avoid rotating the motor while doing so to keep position 2048 set during configuration. It is especially tricky for the leader motors as it is more sensible without the gears, but it's ok if it's a bit rotated.
D. Assemble the arms
Video assembling arms
Follow the video for assembling the arms. It is important to insert the cables into the motor that is being assembled before you assemble the motor into the arm! Inserting the cables beforehand is much easier than doing this afterward. The first arm should take a bit more than 1 hour to assemble, but once you get used to it, you can do it under 1 hour for the second arm.
E. Calibrate
a. Manual calibration of follower arm
Important
  --robot.type=so100 \
  --robot.cameras='{}' \
  --control.type=calibrate \
b. Manual calibration of leader arm
Follow step 6 of the assembly video which illustrates the manual calibration. You will need to move the leader arm to these positions sequentially:
F. Teleoperate
  --control.type=teleoperate
G. Record a dataset
  --control.type=record \
  --control.fps=30 \
  --control.warmup_time_s=5 \
  --control.episode_time_s=30 \
  --control.reset_time_s=30 \
  --control.num_episodes=2 \
  --control.push_to_hub=true
H. Visualize a dataset
echo ${HF_USER}/so100_test
  --local-files-only 1
I. Replay an episode
  --control.type=replay \
  --control.fps=30 \
  --control.episode=0
J. Train a policy
  --policy.type=act \
  --job_name=act_so100_test \
  --device=cuda \
  --wandb.enable=true
Let's explain it:
K. Evaluate your policy
  --control.fps=30 \
  --control.num_episodes=10 \
  --control.push_to_hub=true \
L. More Information
Tip
If you have any questions or need help, please reach out on Discord in the channel #so100-arm.
