Simon Alibert 3c0a209f9f
Simplify configs (#550)
Co-authored-by: HUANG TZU-CHUN <137322177+tc-huang@users.noreply.github.com>
2025-01-31 13:57:37 +01:00
8.4 KiB
Setup
Install LeRobot
On your computer:
  1. Install Miniconda:
mkdir -p ~/miniconda3
rm ~/miniconda3/miniconda.sh
  1. Clone LeRobot:
Teleoperate
  --robot.type=aloha \
  --control.type=teleoperate
Record a dataset
  --control.type=record \
  --control.fps=30 \
  --control.warmup_time_s=5 \
  --control.episode_time_s=30 \
  --control.reset_time_s=30 \
  --control.num_episodes=2 \
  --control.push_to_hub=true
Visualize a dataset
echo ${HF_USER}/aloha_test
Replay an episode
  --control.type=replay \
  --control.fps=30 \
  --control.episode=0
Train a policy
  --policy.type=act \
  --job_name=act_aloha_test \
  --device=cuda \
  --wandb.enable=true
Let's explain it:
Evaluate your policy
  --control.fps=30 \
  --control.num_episodes=10 \
  --control.push_to_hub=true \
  3. We use --control.num_image_writer_processes=1 instead of the default value (0). On our computer, using a dedicated process to write images from the 4 cameras on disk allows to reach constent 30 fps during inference. Feel free to explore different values for --control.num_image_writer_processes.
More
Follow this previous tutorial for a more in-depth explaination.
