2025-03-04 09:57:37 +01:00
24 KiB
Raw Blame History
Using the SO-100 with LeRobot
Table of Contents
A. Source the parts
B. Install LeRobot
Tip
On your computer:
1. Install Miniconda:
2. Restart shell
Video install instructions
4. Clone LeRobot:
Great 🤗! You are now done installing LeRobot and we can begin assembling the SO100 arms 🤖. Every time you now want to use LeRobot you can go to the ~/lerobot folder where we installed LeRobot and run one of the commands.
C. Configure the motors
Note
Throughout this tutorial you will find videos on how to do the steps, the full video tutorial can be found here: assembly video.
Designate one bus servo adapter and 6 motors for your leader arm, and similarly the other bus servo adapter and 6 motors for the follower arm. It's convenient to label them and write on each motor if it's for the follower F or for the leader L and it's ID from 1 to 6 (F1...F6 and L1...L6).
Video finding port
b. Example outputs
Reconnect the usb cable.
c. Troubleshooting
sudo chmod 666 /dev/ttyACM0
sudo chmod 666 /dev/ttyACM1
d. Update config file
@dataclass
        default_factory=lambda: {
                motors={
                    # name: (index, model)
                    "elbow_flex": [3, "sts3215"],
                    "wrist_flex": [4, "sts3215"],
                    "wrist_roll": [5, "sts3215"],
                    "gripper": [6, "sts3215"],
                motors={
2. Assembling the Base
Let's begin with assembling the follower arm base
a. Set IDs for all 12 motors
Video configuring motor
Plug your first motor F1 and run this script to set its ID to 1. It will also set its present position to 2048, so expect your motor to rotate. Replace the text after --port to the corresponding follower control board port and run this command in cmd:
  --brand feetech \
  --model sts3215 \
  --baudrate 1000000 \
  --ID 1
Note
These motors are currently limited. They can take values between 0 and 4096 only, which corresponds to a full turn. They can't turn more than that. 2048 is at the middle of this range, so we can take -2048 steps (180 degrees anticlockwise) and reach the maximum range, or take +2048 steps (180 degrees clockwise) and reach the maximum range. The configuration step also sets the homing offset to 0, so that if you misassembled the arm, you can always update the homing offset to account for a shift up to ± 2048 steps (± 180 degrees).
  --brand feetech \
  --model sts3215 \
  --ID 2
Video removing gears
Follow the video for removing gears. You need to remove the gear for the motors of the leader arm. As a result, you will only use the position encoding of the motor and reduce friction to more easily operate the leader arm.
D. Step-by-Step Assembly Instructions
Step 1: Clean Parts
  • Remove all support material from the 3D-printed parts.
Additional Guidance
Video assembling arms
Note: This video provides visual guidance for assembling the arms, but it doesn't specify when or how to do the wiring. Inserting the cables beforehand is much easier than doing it afterward. The first arm may take a bit more than 1 hour to assemble, but once you get used to it, you can assemble the second arm in under 1 hour.
First Motor
Step 2: Insert Wires
  • Insert two wires into the first motor.
Step 3: Install in Base
Step 4: Secure Motor
  • Fasten the motor with 4 screws. Two from the bottom and two from top.
Step 5: Attach Motor Holder
  • Slide over the first motor holder and fasten it using two screws (one on each side).
Step 6: Attach Motor Horns
  • Install both motor horns, securing the top horn with a screw. Try not to move the motor position when attaching the motor horn, especially for the leader arms, where we removed the gears.
Video adding motor horn
Step 7: Attach Shoulder Part
  • Route one wire to the back of the robot and the other to the left or in photo towards you (see photo).
  • Attach the shoulder part.
Step 8: Secure Shoulder
  • Tighten the shoulder part with 4 screws on top and 4 on the bottom (access bottom holes by turning the shoulder).
Second Motor Assembly
Step 9: Install Motor 2
  • Slide the second motor in from the top and link the wire from motor 1 to motor 2.
Step 10: Attach Shoulder Holder
  • Ensure the wire from motor 1 to motor 2 goes behind the holder while the other wire is routed upward (see photo).
  • This part can be tight to assemble, you can use a workbench like the image or a similar setup to push the part around the motor.
Step 11: Secure Motor 2
  • Fasten the second motor with 4 screws.
Step 12: Attach Motor Horn
  • Attach both motor horns to motor 2, again use the horn screw.
Step 13: Attach Base
  • Install the base attachment using 2 screws.
Step 14: Attach Upper Arm
  • Attach the upper arm with 4 screws on each side.
Third Motor Assembly
Step 15: Install Motor 3
  • Route the motor cable from motor 2 through the cable holder to motor 3, then secure motor 3 with 4 screws.
Step 16: Attach Motor Horn
  • Attach both motor horns to motor 3 and secure one again with a horn screw.
Step 17: Attach Forearm
  • Connect the forearm to motor 3 using 4 screws on each side.
Fourth Motor Assembly
Step 18: Install Motor 4
  • Slide in motor 4, attach the cable from motor 3, and secure the cable in its holder with a screw.
Step 19: Attach Motor Holder 4
  • Install the fourth motor holder (a tight fit). Ensure one wire is routed upward and the wire from motor 3 is routed downward (see photo).
Step 20: Secure Motor 4 & Attach Horn
  • Fasten motor 4 with 4 screws and attach its motor horns, use for one a horn screw.
Wrist Assembly
Step 21: Install Motor 5
  • Insert motor 5 into the wrist holder and secure it with 2 front screws.
Step 22: Attach Wrist
  • Connect the wire from motor 4 to motor 5. And already insert the other wire for the gripper.
  • Secure the wrist to motor 4 using 4 screws on both sides.
Step 23: Attach Wrist Horn
  • Install only one motor horn on the wrist motor and secure it with a horn screw.
Follower Configuration
Step 24: Attach Gripper
  • Attach the gripper to motor 5.
Step 25: Install Gripper Motor
  • Insert the gripper motor, connect the motor wire from motor 5 to motor 6, and secure it with 3 screws on each side.
Step 26: Attach Gripper Horn & Claw
  • Attach the motor horns and again use a horn screw.
  • Install the gripper claw and secure it with 4 screws on both sides.
Step 27: Mount Controller
Assembly complete proceed to Leader arm assembly.
Leader Configuration
For the leader configuration, perform Steps 123. Make sure that you removed the motor gears from the motors.
Step 24: Attach Leader Holder
  • Mount the leader holder onto the wrist and secure it with a screw.
Step 25: Attach Handle
  • Attach the handle to motor 5 using 4 screws.
Step 26: Install Gripper Motor
  • Insert the gripper motor, secure it with 3 screws on each side, attach a motor horn using a horn screw, and connect the motor wire.
Step 27: Attach Trigger
  • Attach the follower trigger with 4 screws.
Step 28: Mount Controller
Assembly complete proceed to calibration.
E. Calibrate
a. Manual calibration of follower arm
Important
  --robot.type=so100 \
  --robot.cameras='{}' \
  --control.type=calibrate \
b. Manual calibration of leader arm
Follow step 6 of the assembly video which illustrates the manual calibration. You will need to move the leader arm to these positions sequentially:
F. Teleoperate
  --control.type=teleoperate
G. Record a dataset
  --control.type=record \
  --control.fps=30 \
  --control.warmup_time_s=5 \
  --control.episode_time_s=30 \
  --control.reset_time_s=30 \
  --control.num_episodes=2 \
  --control.push_to_hub=true
H. Visualize a dataset
echo ${HF_USER}/so100_test
  --local-files-only 1
I. Replay an episode
  --control.type=replay \
  --control.fps=30 \
  --control.episode=0
J. Train a policy
  --policy.type=act \
  --job_name=act_so100_test \
  --device=cuda \
  --wandb.enable=true
Let's explain it:
K. Evaluate your policy
  --control.fps=30 \
  --control.num_episodes=10 \
  --control.push_to_hub=true \
L. More Information
Tip
If you have any questions or need help, please reach out on Discord in the channel #so100-arm.
