2025-03-27 09:55:06 +01:00
26 KiB
Table of Contents
Tip
A. Source the parts
Wired version
B. Install software on Pi
Install OS
Setup SSH
Install LeRobot
On your Raspberry Pi:
1. Install Miniconda:
2. Restart shell
Video install instructions
4. Clone LeRobot:
cd ~/lerobot && pip install --no-binary=av -e ".[feetech]"
C. Install LeRobot on laptop
Tip
On your computer:
2. Restart shell
4. Clone LeRobot:
D. Assembly
SO100 Arms
Configure motors
Motor ID's for mobile robot
Assemble arms
Assemble arms instruction
Mobile base (LeKiwi)
Assemble LeKiwi
Update config
Video finding port
b. Example outputs
Reconnect the usb cable.
c. Troubleshooting
sudo chmod 666 /dev/ttyACM0
sudo chmod 666 /dev/ttyACM1
d. Update config file
@dataclass
    # Network Configuration
    ip: str = "172.17.133.91"
    port: int = 5555
    video_port: int = 5556
        default_factory=lambda: {
                motors={
                    # name: (index, model)
                    "elbow_flex": [3, "sts3215"],
                    "wrist_flex": [4, "sts3215"],
                    "wrist_roll": [5, "sts3215"],
                    "gripper": [6, "sts3215"],
                port="/dev/ttyACM0",
                motors={
                    "left_wheel": (7, "sts3215"),
                    "back_wheel": (8, "sts3215"),
            # Movement
            "forward": "w",
            "backward": "s",
            "left": "a",
            "right": "d",
            "rotate_left": "z",
            "rotate_right": "x",
            # Speed control
            "speed_up": "r",
            "speed_down": "f",
            # quit teleop
            "quit": "q",
    mock: bool = False
Wired version
@dataclass
    ip: str = "127.0.0.1"
    port: int = 5555
            "front": OpenCVCameraConfig(
            "wrist": OpenCVCameraConfig(
                motors={
                motors={
            # Movement
            "forward": "w",
            "backward": "s",
            "left": "a",
            "right": "d",
            "rotate_left": "z",
            # Speed control
            "speed_up": "r",
            "speed_down": "f",
            # quit teleop
            "quit": "q",
    mock: bool = False
E. Calibration
Important
  --robot.type=lekiwi \
  --robot.cameras='{}' \
  --control.type=calibrate \
Wired version
Calibrate leader arm
F. Teleoperate
  --control.type=remote_robot
  --control.type=teleoperate \
  --control.fps=30
Fast 0.4 90
Medium 0.25 60
Slow 0.1 30
Key Action
W Move forward
A Move left
S Move backward
D Move right
Z Turn left
X Turn right
R Increase speed
F Decrease speed
Tip
If you use a different keyboard you can change the keys for each command in the LeKiwiRobotConfig.
Wired version
Troubleshoot communication
hostname -I
ping <your_pi_ip_address>
If the ping fails:
3. Try SSH connection
    sudo raspi-config
4. Same config file
G. Record a dataset
  --control.type=record \
  --control.fps=30 \
  --control.warmup_time_s=5 \
  --control.episode_time_s=30 \
  --control.reset_time_s=30 \
  --control.num_episodes=2 \
  --control.push_to_hub=true
Wired version
H. Visualize a dataset
echo ${HF_USER}/lekiwi_test
  --local-files-only 1
I. Replay an episode
  --control.type=replay \
  --control.fps=30 \
  --control.episode=0
J. Train a policy
  --policy.type=act \
  --job_name=act_lekiwi_test \
  --policy.device=cuda \
  --wandb.enable=true
Let's explain it:
K. Evaluate your policy
  --control.fps=30 \
  --control.num_episodes=10 \
  --control.push_to_hub=true \
