2025-05-05 10:35:32 +02:00
27 KiB
Table of Contents
Tip
A. Source the parts
Wired version
B. Install software on Pi
Install OS
Setup SSH
Install LeRobot
On your Raspberry Pi:
1. Install Miniconda:
2. Restart shell
Video install instructions
4. Clone LeRobot:
5. Install ffmpeg in your environment:
6. Install LeRobot with dependencies for the feetech motors:
C. Install LeRobot on laptop
Tip
On your computer:
2. Restart shell
4. Clone LeRobot:
D. Assembly
SO100 Arms
Configure motors
The instructions for configuring the motors can be found Here in step C of the SO100 tutorial. Besides the ID's for the arm motors we also need to set the motor ID's for the mobile base. These need to be in a specific order to work. Below an image of the motor ID's and motor mounting positions for the mobile base. Note that we only use one Motor Control board on LeKiwi. This means the motor ID's for the wheels are 7, 8 and 9.
Motor ID's for mobile robot
Assemble arms
Assemble arms instruction
Mobile base (LeKiwi)
Assemble LeKiwi
Update config
Video finding port
b. Example outputs
Reconnect the usb cable.
c. Troubleshooting
sudo chmod 666 /dev/ttyACM0
sudo chmod 666 /dev/ttyACM1
d. Update config file
@dataclass
    # Network Configuration
    ip: str = "172.17.133.91"
    port: int = 5555
    video_port: int = 5556
        default_factory=lambda: {
                motors={
                    # name: (index, model)
                    "elbow_flex": [3, "sts3215"],
                    "wrist_flex": [4, "sts3215"],
                    "wrist_roll": [5, "sts3215"],
                    "gripper": [6, "sts3215"],
                port="/dev/ttyACM0",
                motors={
                    "left_wheel": (7, "sts3215"),
                    "back_wheel": (8, "sts3215"),
            # Movement
            "forward": "w",
            "backward": "s",
            "left": "a",
            "right": "d",
            "rotate_left": "z",
            "rotate_right": "x",
            # Speed control
            "speed_up": "r",
            "speed_down": "f",
            # quit teleop
            "quit": "q",
    mock: bool = False
Wired version
@dataclass
    ip: str = "127.0.0.1"
    port: int = 5555
            "front": OpenCVCameraConfig(
            "wrist": OpenCVCameraConfig(
                motors={
                motors={
            # Movement
            "forward": "w",
            "backward": "s",
            "left": "a",
            "right": "d",
            "rotate_left": "z",
            # Speed control
            "speed_up": "r",
            "speed_down": "f",
            # quit teleop
            "quit": "q",
    mock: bool = False
E. Calibration
Important
  --robot.type=lekiwi \
  --robot.cameras='{}' \
  --control.type=calibrate \
Wired version
Calibrate leader arm
F. Teleoperate
Tip
If you're using a Mac, you might need to give Terminal permission to access your keyboard. Go to System Preferences > Security & Privacy > Input Monitoring and check the box for Terminal.
  --control.type=remote_robot
  --control.type=teleoperate \
  --control.fps=30
NOTE: To visualize the data, enable --control.display_data=true. This streams the data using rerun. For the --control.type=remote_robot you will also need to set --control.viewer_ip and --control.viewer_port
Fast 0.4 90
Medium 0.25 60
Slow 0.1 30
Key Action
W Move forward
A Move left
S Move backward
D Move right
Z Turn left
X Turn right
R Increase speed
F Decrease speed
Tip
If you use a different keyboard you can change the keys for each command in the LeKiwiRobotConfig.
Wired version
Troubleshoot communication
hostname -I
ping <your_pi_ip_address>
If the ping fails:
3. Try SSH connection
    sudo raspi-config
4. Same config file
G. Record a dataset
  --control.type=record \
  --control.fps=30 \
  --control.warmup_time_s=5 \
  --control.episode_time_s=30 \
  --control.reset_time_s=30 \
  --control.num_episodes=2 \
  --control.push_to_hub=true
Wired version
H. Visualize a dataset
echo ${HF_USER}/lekiwi_test
  --local-files-only 1
I. Replay an episode
  --control.type=replay \
  --control.fps=30 \
  --control.episode=0
J. Train a policy
  --policy.type=act \
  --job_name=act_lekiwi_test \
  --policy.device=cuda \
  --wandb.enable=true
Let's explain it:
K. Evaluate your policy
  --control.fps=30 \
  --control.num_episodes=10 \
  --control.push_to_hub=true \
