Simon Alibert 1a343c3591
Add support for Stretch (hello-robot) (#409)
Co-authored-by: Remi Cadene <re.cadene@gmail.com>
2024-10-04 18:56:42 +02:00
6.3 KiB
Setup
  • tethered setup
  • untethered setup
Install LeRobot
  1. Install Miniconda:
mkdir -p ~/miniconda3
rm ~/miniconda3/miniconda.sh
    PATH="$HOME/.local/bin:$PATH"
fi
  1. Clone LeRobot:
And install extra dependencies for recording datasets on Linux:
stretch_system_check.py
Model = Stretch 3
Tool = DexWrist 3 w/ Gripper
---- Checking Hardware ----
[Pass] Comms are ready
[Pass] Actuators are ready
---- Checking Software ----
[Pass] Ubuntu 22.04 is ready
[Pass] Firmware is up-to-date
[Pass] ROS2 Humble is ready
    --robot-path lerobot/configs/robot/stretch.yaml
Note: If you run any of the LeRobot scripts below and Stretch is not poperly homed, it will automatically home/calibrate first.
Record one episode:
    --robot-path lerobot/configs/robot/stretch.yaml \
    --fps 20 \
    --root data \
    --repo-id ${HF_USER}/stretch_test \
    --tags stretch tutorial \
    --warmup-time-s 3 \
    --episode-time-s 40 \
    --reset-time-s 10 \
    --num-episodes 1 \
    --push-to-hub 0
    --fps 20 \
    --root data \
    --episode 0
