8.4 KiB
Setup
Install LeRobot
On your computer:
  1. Install Miniconda:
mkdir -p ~/miniconda3
rm ~/miniconda3/miniconda.sh
  1. Clone LeRobot:
Teleoperate
    --robot-path lerobot/configs/robot/aloha.yaml \
    --robot-overrides max_relative_target=5
By adding --robot-overrides max_relative_target=5, we override the default value for max_relative_target defined in lerobot/configs/robot/aloha.yaml. It is expected to be 5 to limit the magnitude of the movement for more safety, but the teleoperation won't be smooth. When you feel confident, you can disable this limit by adding --robot-overrides max_relative_target=null to the command line:
Record a dataset
    --robot-overrides max_relative_target=null \
    --fps 30 \
    --repo-id ${HF_USER}/aloha_test \
    --tags aloha tutorial \
    --warmup-time-s 5 \
    --episode-time-s 40 \
    --reset-time-s 10 \
    --num-episodes 2 \
    --push-to-hub 1
Visualize a dataset
echo ${HF_USER}/aloha_test
Replay an episode
*/!\ FOR SAFETY, READ THIS /!* Replay consists in automatically replaying the sequence of actions (i.e. goal positions for your motors) recorded in a given dataset episode. Make sure the current initial position of your robot is similar to the one in your episode, so that your follower arms don't move too fast to go to the first goal positions. For safety, you might want to add --robot-overrides max_relative_target=5 to your command line as explained above.
    --fps 30 \
    --episode 0
Train a policy
  dataset_repo_id=${HF_USER}/aloha_test \
  policy=act_aloha_real \
  env=aloha_real \
  hydra.run.dir=outputs/train/act_aloha_test \
  hydra.job.name=act_aloha_test \
  device=cuda \
Let's explain it:
  1. We provided the dataset as argument with dataset_repo_id=${HF_USER}/aloha_test.
  2. We provided the policy with policy=act_aloha_real. This loads configurations from lerobot/configs/policy/act_aloha_real.yaml. Importantly, this policy uses 4 cameras as input cam_right_wrist, cam_left_wrist, cam_high, and cam_low.
  3. We provided an environment as argument with env=aloha_real. This loads configurations from lerobot/configs/env/aloha_real.yaml. Note: this yaml defines 18 dimensions for the state_dim and action_dim, corresponding to 18 motors, not 14 motors as used in previous Aloha work. This is because, we include the shoulder_shadow and elbow_shadow motors for simplicity.
  4. We provided device=cuda since we are training on a Nvidia GPU.
Evaluate your policy
  --fps 30 \
  --repo-id ${HF_USER}/eval_act_aloha_test \
  --tags aloha tutorial eval \
  --warmup-time-s 5 \
  --reset-time-s 10 \
  --num-episodes 10 \
  --num-image-writer-processes 1 \
  -p outputs/train/act_aloha_test/checkpoints/last/pretrained_model
  1. There is an additional -p argument which indicates the path to your policy checkpoint with (e.g. -p outputs/train/eval_aloha_test/checkpoints/last/pretrained_model). You can also use the model repository if you uploaded a model checkpoint to the hub (e.g. -p ${HF_USER}/act_aloha_test).
  2. The name of dataset begins by eval to reflect that you are running inference (e.g. --repo-id ${HF_USER}/eval_act_aloha_test).
  3. We use --num-image-writer-processes 1 instead of the default value (0). On our computer, using a dedicated process to write images from the 4 cameras on disk allows to reach constent 30 fps during inference. Feel free to explore different values for --num-image-writer-processes.
More
Follow this previous tutorial for a more in-depth explaination.
