Remi f98200297d
Slightly improve tutorial and README (#370)
2024-08-20 16:41:39 +02:00
49 KiB
Raw Blame History
What You'll Learn:
Although this tutorial is general and can be easily adapted to various types of robots by changing the configuration, it is specifically based on the Koch v1.1, an affordable robot. The Koch v1.1 consists of a leader arm and a follower arm, each with 6 motors. It can work with one or several cameras to record the scene, which serve as visual sensors for the robot.
First, install the additional dependencies required for Koch v1.1 by running one of the following commands.
Using pip:
pip install -e ".[koch]"
Or using poetry:
poetry install --sync --extras "koch"
Copy pasting python code
It will automatically:
Reconnect the usb cable.
sudo chmod 666 /dev/ttyACM0
sudo chmod 666 /dev/ttyACM1
    port=leader_port,
    motors={
        # name: (index, model)
        "gripper": (6, "xl330-m077"),
    port=follower_port,
    motors={
        "gripper": (6, "xl330-m288"),
leader_arms:
  main:
    motors:
      elbow_flex: [3, "xl330-m077"]
      wrist_flex: [4, "xl330-m077"]
      wrist_roll: [5, "xl330-m077"]
      gripper: [6, "xl330-m077"]
follower_arms:
  main:
    motors:
      elbow_flex: [3, "xl330-m288"]
      wrist_flex: [4, "xl330-m288"]
      wrist_roll: [5, "xl330-m288"]
      gripper: [6, "xl330-m288"]
leader_arm.connect()
1. Unplug the power cord
3. Re-plug the power cord
Press Enter to continue...
*Follow the procedure*
follower_arm.connect()
Troubleshooting:
Known failure modes:
Steps:
  3. Launch the software.
  5. For each motor in turn:
print(leader_pos)
print(follower_pos)
# Get the current position
position[0] += 10
position -= 30
# Update gripper by +30 steps
position[-1] += 30
Finally, disconnect the arms:
leader_arm.disconnect()
follower_arm.disconnect()
b. Teleoperate your Koch v1.1 with KochRobot
Instantiate the KochRobot
Before you can teleoperate your robot, you need to instantiate the KochRobot using the previously defined leader_arm and follower_arm.
For the Koch robot, we only have one leader, so we refer to it as "main" and define it as leader_arms={"main": leader_arm}. We do the same for the follower arm. For other robots (like the Aloha), which may have two pairs of leader and follower arms, you would define them like this: leader_arms={"left": left_leader_arm, "right": right_leader_arm},. Same thing for the follower arms.
You also need to provide a path to a calibration file, such as calibration_path=".cache/calibration/koch.pkl". More on this in the next section.
Run the following code to instantiate your Koch robot:
from lerobot.common.robot_devices.robots.koch import KochRobot
robot = KochRobot(
    calibration_path=".cache/calibration/koch.pkl",
Calibrate and Connect the KochRobot
Next, you'll need to calibrate your robot to ensure that the leader and follower arms have the same position values when they are in the same physical position. This calibration is essential because it allows a neural network trained on one Koch robot to work on another.
When you connect your robot for the first time, the KochRobot will detect if the calibration file is missing and trigger the calibration procedure. During this process, you will be guided to move each arm to three different positions.
robot.connect()
Connecting main follower arm
Connecting main leader arm
Missing calibration file '.cache/calibration/koch.pkl'. Starting calibration procedure.
Running calibration of main follower...
Move arm to zero position
Move arm to rotated position
Move arm to rest position
Running calibration of main leader...
Calibration is done! Saving calibration file '.cache/calibration/koch.pkl'
Verifying Calibration
print(leader_pos)
print(follower_pos)
Example output:
import tqdm
seconds = 30
frequency = 200
Alternatively, you can teleoperate the robot using the teleop_step method from KochRobot.
Run this code to teleoperate:
    robot.teleop_step()
print(follower_pos)
print(observation)
print(leader_pos)
print(action)
Expected output:
Asynchronous Frame Recording
Disconnecting the Robot
robot.disconnect()
v4l2-ctl --list-devices
You should see an entry like:
/dev/video1
>>> Format Video Capture:
Instantiate an OpenCVCamera
Camera found at index 0
Camera found at index 1
Connecting cameras
camera.connect()
color_image = camera.read()
print(color_image.shape)
print(color_image.dtype)
(1080, 1920, 3)
uint8
(480, 640, 3)
uint8
Disconnecting the camera
camera.disconnect()
robot = KochRobot(
    cameras={
robot.connect()
torch.Size([3, 480, 640])
cameras:
  laptop:
    camera_index: 0
    fps: 30
    width: 640
    height: 480
  phone:
    camera_index: 1
    fps: 30
    width: 640
    height: 480
It contains
  --robot-overrides \
  --robot-overrides \
    '~cameras'
import time
record_time_s = 30
fps = 60
states = []
actions = []
    busy_wait(1 / fps - dt_s)
Also, store your Hugging Face repositery name in a variable (e.g. cadene or lerobot). For instance, run this to use your Hugging Face user name as repositery:
  --fps 30 \
  --root data \
  --tags tutorial \
  --warmup-time-s 5 \
  --episode-time-s 30 \
  --reset-time-s 30 \
  --num-episodes 2
It contains:
Troubleshooting:
pip uninstall opencv-python
c. Visualize all episodes
  --root data \
  --fps 30 \
  --root data \
  --episode 0
a. Use the train script
  policy=act_koch_real \
  env=koch_real \
  device=cuda \
Let's explain it:
override_dataset_stats:
  observation.images.laptop:
  observation.images.phone:
  input_shapes:
  input_normalization_modes:
fps: 30
env:
  task: null
  state_dim: 6
  action_dim: 6
  fps: ${fps}
CKPT=010000
5. Evaluate your policy
Now that you have a policy checkpoint, you can easily control your robot with it using methods from KochRobot and the policy.
inference_time_s = 60
fps = 30
policy.to(device)
    # with batch dimension
    for name in observation:
        if "image" in name:
    # Remove batch dimension
    action = action.squeeze(0)
    action = action.to("cpu")
    # Order the robot to move
    robot.send_action(action)
  --fps 30 \
  --root data \
  --tags tutorial eval \
  --warmup-time-s 5 \
  --reset-time-s 30 \
  --num-episodes 10 \
  --root data \
6. Next step
