Simon Alibert fe483b1d0d
Remove poetry.lock (#737)
2025-02-17 12:03:16 +01:00
50 KiB
Raw Blame History
What You'll Learn:
Using pip:
pip install -e ".[dynamixel]"
Using poetry:
Using uv:
uv sync --extra "dynamixel"
pip uninstall opencv-python
  --robot.type=koch \
  --control.type=teleoperate
It will automatically:
  --brand dynamixel \
  --model xl330-m288 \
  --baudrate 1000000 \
  --ID 1
  --brand dynamixel \
  --ID 2
Reconnect the usb cable.
    motors={
        # name: (index, model)
        "gripper": (6, "xl330-m077"),
    motors={
        "gripper": (6, "xl330-m288"),
@dataclass
        default_factory=lambda: {
                motors={
                    "gripper": [6, "xl330-m077"],
                motors={
                    "gripper": [6, "xl330-m288"],
leader_arm.connect()
1. Unplug the power cord
3. Re-plug the power cord
Press Enter to continue...
*Follow the procedure*
follower_arm.connect()
Troubleshooting:
Known failure modes:
Steps:
  3. Launch the software.
  5. For each motor in turn:
print(leader_pos)
print(follower_pos)
# Get the current position
position[0] += 10
position -= 30
# Update gripper by +30 steps
position[-1] += 30
Finally, disconnect the arms:
leader_arm.disconnect()
follower_arm.disconnect()
robot.connect()
Connecting main follower arm
Connecting main leader arm
Move arm to zero position
Move arm to rotated position
Move arm to rest position
Verifying Calibration
print(leader_pos)
print(follower_pos)
Example output:
Teleoperate your Koch v1.1
import tqdm
seconds = 30
frequency = 200
Run this code to teleoperate:
    robot.teleop_step()
print(follower_pos)
print(observation)
print(leader_pos)
print(action)
Expected output:
Asynchronous Frame Recording
Disconnecting the Robot
robot.disconnect()
v4l2-ctl --list-devices
You should see an entry like:
/dev/video1
>>> Format Video Capture:
Instantiate an OpenCVCamera
Camera found at index 0
Camera found at index 1
Connecting cameras
camera_config = OpenCVCameraConfig(camera_index=0)
camera = OpenCVCamera(config)
camera.connect()
color_image = camera.read()
print(color_image.shape)
print(color_image.dtype)
(1080, 1920, 3)
uint8
(480, 640, 3)
uint8
Disconnecting the camera
camera.disconnect()
robot = ManipulatorRobot(
    cameras={
robot.connect()
torch.Size([3, 480, 640])
  --robot.type=koch \
It contains
  --robot.type=koch \
  --robot.cameras='{}' \
import time
record_time_s = 30
fps = 60
states = []
actions = []
    busy_wait(1 / fps - dt_s)
a. Use the record function
  4. Checkpoints are done during recording, so if any issue occurs, you can resume recording by re-running the same command again with --control.resume=true. You might need to add --control.local_files_only=true if your dataset was not uploaded to hugging face hub. Also you will need to manually delete the dataset directory to start recording from scratch.
  --robot.type=koch \
  --control.type=record \
  --control.fps=30 \
  --control.warmup_time_s=5 \
  --control.episode_time_s=30 \
  --control.reset_time_s=30 \
  --control.num_episodes=2 \
  --control.push_to_hub=true
It contains:
Troubleshooting:
c. Visualize all episodes
  --robot.type=koch \
  --control.type=replay \
  --control.fps=30 \
  --control.episode=0
Note: You might need to add --control.local_files_only=true if your dataset was not uploaded to hugging face hub.
a. Use the train script
  --policy.type=act \
  --job_name=act_koch_test \
  --device=cuda \
  --wandb.enable=true
Note: You might need to add --dataset.local_files_only=true if your dataset was not uploaded to hugging face hub.
Let's explain it:
CKPT=010000
5. Evaluate your policy
inference_time_s = 60
fps = 30
policy.to(device)
    # with batch dimension
    for name in observation:
        if "image" in name:
    # Remove batch dimension
    action = action.squeeze(0)
    action = action.to("cpu")
    # Order the robot to move
    robot.send_action(action)
a. Use our record function
  --robot.type=koch \
  --control.fps=30 \
  --control.num_episodes=10 \
  --control.push_to_hub=true \
6. Next step
